20 Most Recent Pelican TSA Lock Questions & Answers
Yes, that never fixes the problem. This explains why, and why you can't diagnose television problems on an online forum. The television sections are really only for help with manuals and remote codes.
Here are similar questions that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ? Or
Turns on and sound works fine, but the picture is distorted (solarized? polarized? not sure what the term is) I replaced the main board, but that didn't fix it.
Or
I have an LG 55LM6200-UE with a dim lower-left. I just replaced both LED strips with no resolution. There is no physical obstruction visible, so this has to be a cable or board problem, right?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work as it should! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what it does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part you put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'NO Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous sellers use it as an excuse to get money for selling items that may, or may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $5 in parts and a couple of hours labour. It's not the fix you want to hear, but it is the best advice.
Andrew - Fixya Moderator
Locks &... | Answered on May 15, 2020
Open it up.
Remove the battery.
Leave it for 15 minutes.
Install a NEW battery, yours is nearly depleted.
The battery doesn't have enough power to take your programming demands..
I fixed all the errors in your written question :>)
Locks &... | Answered on May 13, 2020
WE HAVE NO IDEA IF OMEGA MAKES THEM OR NOT . AS ANY NON OWNER WOULD HAVE NO INTEREST IN FINDING OUT ASK THE MANUFACTURER'S TECH SUPPORT
Locks &... | Answered on Apr 21, 2020
https://www.youtube.com/watch?v=Q65rBwVvLDs
https://fccid.io/NUL450412ZWV/User-Manual/Users-Manual-3342158
Locks &... | Answered on Mar 06, 2020
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
Locks &... | Answered on Mar 02, 2020
ask the maker, only they have a cure. (their design !)
you posted with no maker of safe told nor model.
impossible question.
btw some have hidden key, but you lost that too..
Locks &... | Answered on Feb 27, 2020
Probably not! Sounds like something was damaged besides the plug. Clicking could be a tooth on the gear was damaged and now slips. The way I repair or determine what's wrong with locks is to take them off and start by manually operating the strike and then check / test the rest of the lock as I assemble it back to the door. If the gear is damaged, you should be able to see that once the lock is disassembled. Cross your fingers you find some debris in the lock and thats all....
Locks &... | Answered on Feb 07, 2020
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell [email protected]
Good luck
Locks &... | Answered on Jan 13, 2020
Pelican TSA Lock Logo
1 questions posted
Top Pelican Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Pelican Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Pelican Locks & Locksmithing
Most Popular Question
locked out digital home safe key inside
  • Locks & Locksmithing
