20 Most Recent
Kicker KX500.2 Car Audio Amplifier Questions & Answers
My amp would turn on and off and one time it just ...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Contact Kicker to have them repair.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Kicker KX500.2...
Answered
on Dec 18, 2014
I have a kicker 500.2
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Kicker KX500.2...
Answered
on Dec 18, 2014
Kicker Amplifier v. Pioneer Head Unit
GET RED POS+ LONG WIRE 2 BATTERY 2 WERE UR AMP IS GANA GO CONECT IT TO THE AMP POS+ (2)GET NEG- WIRE CONECT 2 WERE THE NEG- IS ON THE AMP THEN THE OTHER END OF SAME NEG- WIRE FIND PLACE NEXT 2 AMP WERE U COULD SCREW NEG- TO CAR METL CLOSE 2 AMP (3)GET LONG REMOTE ANT. WIRE CONECT IT TO WERE THE REMOTE ANT CONECTION IS ON AMP THEN SEND IT TO UR PIONEER IS AND FIND REMOTE ANT . ON UR PIONEER HEAD AND CONECT IT SO IT SHOULD BE CONECTED TO UR AMP LAST PART GET THE LONG RC PLUUGS AND CONECT TO UR AMP THEN RUN THEM TO UR PIONEER HEAD WERE THE RC PLLUGS INPUT IS THEN IT SHUD BE DONE!!!
Kicker KX500.2...
Answered
on Mar 13, 2010
I have a 2channell FE-402 fusion amp,with a fusion
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Kicker KX500.2...
Answered
on Jun 06, 2009
Bought some 6x9's now need an amp to power them up
I know this is a very broad statement, but your budget will allow for what you buy. You will want a nice 2 channel 50 watt rms amp min. 50 watts is a lot of power for those speakers and you will be happy. I would recommend if your budget allowed a nice kenwood, Alpine, Diamond Audio or MB quart. Just make sure whatever you buy that it is a low noise A/B class amp. Nothing to special.
Take care and have fun!!
Kicker KX500.2...
Answered
on Jun 03, 2009
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Kicker KX500.2...
Answered
on Apr 01, 2009
I have a 4 channel Kicker amp, sub is bridged (svc 4ohm) and I have (4) door speakers (4ohm each) running on two of the channels, I have a android head unit and it's in a 08 Silverado, whenever the truck is 1st started, the speakers emit a chirping sound and the amp goes into protect mode, if you turn off the truck and restart it, most of the time protect mode goes off and then after around 15 minutes it goes into protect again and starts chirping, and again you can stop, turn off the truck and restart it and it will be fine again, any idea what my issue is?
If you connected speakers in parallel then two speakers have combined resistance of 2 ohms. You need to connect speakers in series
Kicker Car Audio...
Answered
on Oct 29, 2020
