20 Most Recent Kicker KX2500.1 Car Audio Amplifier Questions & Answers
0answers
Diode
Be the first to answer 5/3/2013 3:31:59 AM • Kicker KX2500.1... • Posted on May 03, 2013Be the first to answer
I brought a kicker solo
Nice amp.
Are you requesting installation information for your amp and sub?
In my opinion, hooking it up is the best way to determine if the gear is in good working order. Do you have a head unit or source handy?
Here's a link to the installation manual.
Please post if I misunderstood or can be of more assistance.
I hope that helps.
4/20/2010 4:33:21 AM • Kicker KX2500.1... • Answered on Apr 20, 2010
tip
Kicker KX2500 Manual Download
Download Kicker KX2500 Car Audio Amplifier Installation Manual
Have you misplaced your Kicker KX2500 Car Audio Amplifier Owners Manual?
Would you like a digital, searchable, pdf version of the Kicker KX2500 Car Audio Amplifier Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
11/12/2009 5:48:36 PM • Kicker KX2500.1... • Answered on Nov 12, 2009
2answers
DHD NTX-3107 Wont turn on anymore.
Hi, Please check that you've swapped out any associated batteries of your amplifier. And also, please double check that you're using compatible fuses as some manufacturers build their machine to only work with their own products like fuses. If all of these things fail, you might need to reach out to the manufacturer of the product if you don't have access to the manual for troubleshooting. Thank you.
10/21/2022 12:49:35 AM • Kicker Car Audio... • Answered on Oct 21, 2022
Kicker CXA 400.1 ...accidentally hooked up + and - backwards now just keeps blowing inline fuse immediately. How can i fix this? Inside amp nothing looks damaged
Send it back to maker for repair.
CX400.1 Mono Amplifier - KICKER
https://www.kicker.com > CXA4001-400-Watt-Mono-C... Using efficient Class-D power, the CXA400.1 features a variable bass boost with KickEQ™, giving you as much as a 6dB of extra bump with a simple turn of the ..
10/9/2022 7:12:08 PM • Kicker Car Audio... • Answered on Oct 09, 2022
I have a taramp 5k and keep burning subs so I am getting new subs from kicker and have a choice of 2k or 3k amps but don’t know which too choose 2k will under power but I feel 3k is just right just do t want to burn no more subs need advice 2 15” l7s subs
Kicker advises not to overdrive the system because it can burn stuff up. Having that much power does not mean you listen to it that loud. It means there is something called headroom in amp range that allows it to supply the needed power for bass response when it has to. There is also the issue of impedence of the speakers and how it affects wattage. Lower impedence impedence results in higher wattage at the cost of heat. There is nothing listed I see that can take all that amp has to offer. Also be sure that the cross over is working to seperate the signals to the speaker.
7/12/2022 1:51:37 AM • Kicker Car Audio... • Answered on Jul 12, 2022
Can Car speakers hook up to house stereo?
Yes but you will need to put them in a wooden box
6/11/2022 7:54:52 AM • Kicker Car Audio... • Answered on Jun 11, 2022
2answers
I have two kicker compc dvc 4ohm 15s in a ported box. Can I hook it up to a Mmats pro audio d700.1 mono amp?
From the information I could find on that amplifier, it is stable at one ohm and provides 700 W RMS at that resistance. With two four ohm dvc subs you can wire them parallel/parallel for a final load of one ohm. 85d7eda6-f8f2-4e4d-8fe5-68f3dc5b1895-qgeb1bdcdbvijzq2zc5badm3-d-0.png
2/27/2022 7:49:45 PM • Kicker Car Audio... • Answered on Feb 27, 2022
Can a Mmats professional audio mono d700.1 amp pushpush 2 kicker compc dvc 4ohm 15s in a ported box?
" this amp "? The one that only you can see? :>D
2/4/2022 5:09:07 AM • Kicker Car Audio... • Answered on Feb 04, 2022
2answers
Kicker cxa1200 goes into protection only when left rca channel is plugged in, right channel works fine
it appears that the left channel is defective, repair or replace
12/20/2021 1:22:15 AM • Kicker Car Audio... • Answered on Dec 20, 2021
Kicker KX2500.1 Car Audio Amplifier Logo
6 questions posted
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
brought kicker solo
  • Car Audio & Video
