20 Most Recent Subaru 1999 Impreza Outback A/C Compressor Questions & Answers
Single white Female.... has a sweet 1999 Subaru Outback Impreza, manual. The check engine light is on all the time but the car runs perfectly! Every now and then the check engine light blinks - seems
That light warns of impending problems that can be as simple as low fluids. Have a serviceman check under the hood before a problem develops. It might just need oil or a tune-up. He should be able to turn off the warning once issue is addressed.
11/20/2014 4:04:26 PM • Subaru 1999... • Answered on Nov 20, 2014
2answers
What is reason for starter feedback contact open and what is the solution for this in atlas copco ga110 compressor
img20240331004228-bwjef2euadyfinuzpp4qqge2-d-0.jpg how to solve the this alaram what is the reason getting this alaram ,how to fault finding
3/30/2024 7:23:51 PM • Air Tools &... • Answered on Mar 30, 2024
Air compressor not starting on everstart jump starter JUS750CE. After hitting "AIR" button, the unit just beeps with LED display showing 12.6 volts instead of PSI. Charging button is turned off
Not being sure about this model but do you have the air hose connected to the tire vent and does it meet the minimum requirements? This may be the only way that the compressor can know how much pressure is in the tire and to start counting.
3/24/2024 2:44:50 AM • Air Tools &... • Answered on Mar 24, 2024
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
3/20/2024 12:02:48 AM • Air Tools &... • Answered on Mar 20, 2024
Compressor tripping on OVER RATIO,what could be the problem?
Change of Pressure sensor. Or Recalibrating is required.
3/15/2024 11:32:33 AM • Air Tools &... • Answered on Mar 15, 2024
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes. Read your user manual for more information.
3/14/2024 8:08:46 AM • Air Tools &... • Answered on Mar 14, 2024
How to use a Rocafix MS 500 as a nailer?
You cannot. It is a hand operated staple gun.
3/14/2024 8:06:32 AM • Air Tools &... • Answered on Mar 14, 2024
Where is restart button mac5200 compressor
It has a pressure valve that can give trouble if moisture enters in damp conditions but no restart button.
3/14/2024 7:14:37 AM • Air Tools &... • Answered on Mar 14, 2024
Wiring diagram color code harbor. Freight 95851 camara
95851 comes up as a scissor jack. Please check your descrition and try again.
3/14/2024 7:12:06 AM • Air Tools &... • Answered on Mar 14, 2024
Compair C55 14 error code SPN167 towable compressor
Firstly I would check the oil level and then use clean fuel and filters.
3/14/2024 7:09:45 AM • Air Tools &... • Answered on Mar 14, 2024
Bostitch N80SB Pneumatic Stick Nailer. Air leaking around head of N80SB.
Question edited for a lot more clarity. If you still have it, replace the seals and lubricate. https://www.google.com/search?q=Bostitch+N80sb+Parts ..
3/14/2024 3:44:50 AM • Air Tools &... • Answered on Mar 14, 2024
0answers
Subaru 1999 Impreza Outback A/C Compressor Logo
1 questions posted
Top Subaru Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Subaru Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Subaru Air Tools & Compressors
Most Popular Question
single white female sweet 1999
  • Air Tools & Compressors
