To revolveri, You need to turn your head unit up to about 3/4 of the way up the set your input gain of your amp or amps to the point where the output is distored, then turn it back down a little till the distorion is gone. Then adjust the other settings to your liking. It's a good Idea to keep your lows, mids, and highs crossed over correctly so you dont miss out on any of those frquencies. It's basicly how you like it to sound, it's your car and your system.
To jasons247, when that happens try going into the diagnostic mode to see any trouble code faults. This amp will store fault codes then I do beleive in the manual you can look up those fault codes for the problems. If you can't get into the diagnostic mode then your amp needs servicing like it says. If you have a warranty use it if not take it to a repair shop and have them trouble shoot it, They will charge a bench check charge to see what's wrong with it, so find that out first. If they do figure out what's wrong with it chances are they will charge you big bucks to fis, but find out first. If you need it repaired at a cheap price I repair car amps everyday and have repaired 2 of these amps that had blown output transistors the other amp is a different story. A guy shipped me one from Ohio, and the other guy shipped me the amp from Wisconsin. I don't charge like the other online repair shops do. I have my own shop and have 2 degrees in electronics. I have a young man from E-bay that sends all his broken amps he buys from auctions to and I repair them. He pays for parts and shipping both ways. I just keep track of what I fix for him then if I need some mone he puts it into my pay-pal account or if I see something I want from his store, we wor out a deal. I tell you this just to give you some insight as to what I can do for you. This paticular amp you do not want to try and repair yourself. That's what happend to one of these amps I repaired, the kid tried repairing it himself and I had to order a board from kicker to fix it cause of the digital circuitry it uses. If interested let me know. Leave me an E-mail.
To Guest, same thing applies to you, check your diagnostics out on the amp. If you lost the manual you can download it from kickers site. Good luck to all and if you need any further assistance let me know. Thanks. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/mark_b53a7494531bf96d
