20 Most Recent Yukon NVB Viking 3.5x40 RX Questions & Answers
Hello, clean the outside of the lens with a good optical cleaner. If you have, then trying adjusting the focus for each eye. Try both ends of this binocular at one eye at time; such as, left first, then the right eye until there are focused. That is if you can focus the optical end and they leave you with the eye lens for focus. Let me know how it works out. stewbsion
Yukon NVB Viking... | Answered on Aug 15, 2011
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Yukon Optics | Answered on Sep 24, 2011
Check out Crosman site they have many parts an lots of parts fit older an new guns.
Optics | Answered on May 17, 2020
It may be the year 1967. Because I find greener gun number 79259 was made in 1967.
Optics | Answered on May 15, 2020
Trying to figure out how old my Whirlpool washer is Locate your machine's nameplate, which contains both the model and serial numbers. On top-loading Whirlpool washing machines, open the lid and look for the tag at the top rear of the tub. On front-loading washers, the tag is usually inside the door or near the bottom of the left or right side of the cabinet. If the tag is not in one of those places, pull the machine away from the wall and check the rear. Record the serial number with a pencil and paper or take a photograph. Be sure to record the serial number, not the model number. Decode the serial number at an online source like Appliance Cafe or Appliance 411 (links in Resources). Whirlpool serial numbers include a code in the second character for the year the product was built. Before 1990, the character was a number; from 1990 to 2010 the character was a letter. The number sequence started over in 2011.
Optics | Answered on May 13, 2020
https://www.youtube.com/watch?v=s90HADv-mJk
https://www.ebay.com/itm/NEW-BATTERY-CAP-COVER-SCREW-FOR-BUSHNELL-TOUR-V3-OR-V3-SLOPE-GOLF-RANGEFINDER-/264409429458
Optics | Answered on Mar 13, 2020
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Optics | Answered on Feb 20, 2020
TRY THE MANUFACTURER WE DO NOT HAVE REPLACEMENTS FOR ANY THING
Optics | Answered on Jan 15, 2020
You should know what you paid for it, whatever it is. If you are enquiring about its value, however - Fixya does not do appraisals or valuations
Bottle-shaped cartridges and long barrels cry out for Cordite, shame it is no longer made but research the burn rate and try and match it with a powder...
Optics | Answered on Jan 09, 2020
Yukon NVB Viking 3.5x40 RX Logo
1 questions posted
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
View Most Popular
Yukon Optics
  • Yukon Optics
Most Popular Question
right eye blurey dirty
  • Optics
