20 Most Recent Kicker Solo-Baric L7 12'' Car Speaker Questions & Answers
To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
Kicker... | Answered on Nov 12, 2012
Check your RCA cables to make sure you are getting signal. The amp isn't in protection is it? Also, if you have a multimeter, you can check to see if you are getting any power out to the speakers. Also, check to make sure your subs aren't blown. Keep me posted.
Kicker... | Answered on Aug 26, 2011
RTV BLUE OR BLACK... works every time. Just don't rush it and let it dry!!!
Kicker... | Answered on Aug 11, 2011
THERE ARE NO SPECIFIC RULES FOR SPEAKER PLACEMENT IN ANY VEHICLE, BUT WHAT USUALLY HAPPENS WHEN FACING THEM AGAINST THE REAR WALL IS WHAT IS REFERRED TO AS "CORNER LOADING" WHICH IS AN ACOUSTIC REINFORCEMENT OF A PARTICULAR BAND OF FREQUENCIES WITHIN THE BASS REGION. YOU REALLY JUST HAVE TO TRY SEVERAL POSITIONS AND SEE WHICH ONE SOUNDS THE BEST. SOMETIMES WHEN CORNER LOADING, YOU WILL GAIN THE LOW BASS REGION AND SACRIFICE THE UPPER BASS REGION, SO JUST TRY TO USE SOME MUSIC THAT HAS BASS TONES FROM THE LOWEST TO HIGHEST AND LISTEN CAREFULLY, MOST PEOPLE WILL FIND THAT CORNER LOADING MOST TIMES WILL ADD OUTPUT TO THE SYSTEM. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Kicker... | Answered on Jan 14, 2010
As an authorized dealer - i can tell you that kicker WILL NOT repair any subwoofer that is out of warranty.
They use a proprietary cone assembly and do not sell it to ANYONE to make repairs.
Unless you know someone that works there personally - you have a doorstop on your hands.
I have a dead L712 in the shop if you would like matching doorstops :D
Sorry to be the bearer of bad news!
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question (although it may not be the answer you wanted to hear - it is correct.)
Kicker... | Answered on Mar 21, 2009
WHAT DOES DRAGGING MEAN?
I USE TO BE AN CAR AUDIO INSTALLER ,WHATS YOUR QUESTION?I NEED MAKES AND MODELS AND HOW ITS SETUP AND WITH WHAT..IF THE WOFFER IS MAKING A STUDERING SOUND WHEN A VOICWEE IS BE PLAYED ITS BECAUSE YPUR NOT SENDING LOW FREQ> SOIUND TO SUB ONLY,.
Kicker... | Answered on Jan 29, 2008
That is called a suround my freind. depending on the exact size of the foam surround they are available with good instructions at many many places that do speaker repairs on-line. Heres one I have used in the past http://www.simplyspeakers.com/2doityourself.htm?src=overture Like I said there are tons of them available on-line. Simply search for speaker surround repair. Good Luck Please do not forget to rate this thread.
Kicker... | Answered on Jan 03, 2007
Here is your answer: https://www.fixya.com/support/t10052958-sx650_1_kicker_locked
Kicker Car Audio... | Answered on Oct 04, 2020
Hi Hector, if all the wiring is connected properly, you then mite have a problem on the circuit board, or with the subwoofer itself. While its switched off try moving the switches one or two times just in case there is a dry contact. Next would be to take in the unit for an independant bench test before opening the unit. Cheers.
Kicker Car Audio... | Answered on Apr 04, 2020
About all you can do if your really wanting to "fix" it, is tear it apart & completely recoil both voice coils.
Otherwise you can just run it on the one good side like a single voice coil sub.
Kicker Car Audio... | Answered on Oct 08, 2019
It belongs in the 4 port molex that has the RED, Blue Blue/white and last wire should be black
Kicker Car Audio... | Answered on Jul 24, 2019
Car Audio & Video Logo
Popular Tags
14 questions posted
Top Kicker Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
2 12
  • Car Audio & Video
