20 Most Recent Utilitech 1/3-HP Cast-Iron 95 GPM Sewage Sump Pump 58117-UTL1 Questions & Answers
1/3 Hp Utilitech pump starts, pumps for 15 seconds and then kicks on and off. Just about field stripped the pump to find an overload device but can't find one. The pump runs smoothly when it runs.
It sounds like the pump is oversized and is short cycling because it pumps down too quickly. I recommend a much wider pit, or a 1/4 hp pump.
3/20/2017 8:02:31 PM • Utilitech 1/3-HP... • Answered on Mar 20, 2017
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
8/21/2015 11:09:23 PM • Utilitech 1/3-HP... • Answered on Aug 21, 2015
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
6/12/2015 5:53:59 PM • Utilitech 1/3-HP... • Answered on Jun 12, 2015
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
10/18/2014 1:08:23 AM • Utilitech 1/3-HP... • Answered on Oct 18, 2014
My alarm is going off. What do I need to do?
turn it off
9/3/2014 1:11:12 AM • Utilitech 1/3-HP... • Answered on Sep 03, 2014
Pump won't shut-ff
Hi Ron... Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water. Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float Bud
4/25/2013 3:41:59 AM • Utilitech 1/3-HP... • Answered on Apr 25, 2013
Where can I get utilitech pump parts for #0313833
Utilitech replacement parts:
Customer service 1-866-994-4148
2/7/2019 6:50:37 AM • Utilitech... • Answered on Feb 07, 2019
Sump pump will not pump water, won' turn on, floater up
There are a few things that could cause this problem to come up. Pretty much all of them do require taking the sump pump apart a bit though. I would suggest having a professional come to help you if you don't have much experience with this kind of work. Hopefully you can get this resolved fairly quickly. http://www.rite-waywaterproofing.com/sump_pump_install.php
3/23/2016 9:46:26 PM • Utilitech... • Answered on Mar 23, 2016
View Pump # 0313504
Are you trying to view it, once it has already been installed? If that is the case, you will have some trouble. You will need to call a professional (preferably the installer) to come help you. You might even need a snake camera. Elisa Jed ' http://www.wellservicetampabay.com/Pump_Repair_Brooksville_FL.html
8/26/2014 3:04:11 PM • Utilitech... • Answered on Aug 26, 2014
Utilitech pump wont build pressure
my pump does not hold pressure when the water is running cuts on at 20psi and the pressure keep droping.
8/18/2014 10:42:12 PM • Utilitech... • Answered on Aug 18, 2014
New utilitec pump cuts on and off, won't hold pressure
I do not know your system however it sounds like it is on a well system. If so the pressure tank is water bound and needs to be drained. There is a air regulator that needs repair or replacement. I am just taking a guess.
8/18/2014 10:39:13 PM • Utilitech... • Answered on Aug 18, 2014
I have a pump #WO313834UTPQP1W
Hi Tata, There is no match appearing across the web for that identification number of your pump. There may be character missing or swapped. Please verify the support information. Here is a link offering the pumps at replacement cost which may be more viable looking at the price and effort you may invest in the repairs. Take a look. utilitech parts for pumps BuyCheapr com . At the bottom of the page above, a variety of options exist. Below is one of them Here is a resource further in on the first sight to examine Top Results for pump parts Happy wrenching. Fare. Well.
6/25/2014 7:57:59 PM • Utilitech... • Answered on Jun 25, 2014
Utilitech 1/3-HP Cast-Iron 95 GPM Sewage Sump Pump 58117-UTL1 Logo
12 questions posted
Top Utilitech Plumbing Experts
Paul Carew
 Mikey
Mikey
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Utilitech Plumbing
  • Utilitech Plumbing
Most Popular Question
pump won 39 t shut ff
  • Plumbing
