20 Most Recent Norelco 3605 X Electric Shaver Questions & Answers
The red piece is the voltage switch. It goes at the bottom of the shaver and the rectangular part will correspond to the rectangular cutout at the bottom. The copper contacts will go against the circuit board
Norelco 3605 X... | Answered on Jul 03, 2017
There is a red switch on the bottom that allows you to switch the voltage from 120V to 240V
Norelco 3605 X... | Answered on Nov 25, 2014
philips norelco HQ56 replacement heads for electric shaver norelco 3605x blades replacement parts.
Norelco 3605 X... | Answered on Jun 13, 2013
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Norelco 3605 X... | Answered on Jul 14, 2011
The battery for model 3605X can be found at shaveroutlet.com for a price of $12.49. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
To replace, start by removing the 4 screws on the back and then removing the back cover. You can then access the battery. For easiest replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Norelco 3605 X... | Answered on Mar 18, 2011
Model 3605X requires just one battery. You will find this size battery at shaveroutlet.com. See link below
Norelco 3605 X... | Answered on Feb 25, 2011
Most likely, the battery is dead. To change the battery on model 3605X, you need to remove the back cover by removing the 4 screws. You will need to extent the long hair trimmer to reveal 2 of them. Once back is removed, you can access the batteries. You may find it easier to work with if you remove the 'guts' by taking off the two clips that hold the motor to the shaver. You can then lift everything out.
Simply unsolder the old battery and solder in a new one. Reassemble in reverse order.
You will find this battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
Norelco 3605 X... | Answered on Sep 19, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Norelco 3605 X... | Answered on Sep 05, 2010
It is a #8 torx screwdriver. if needed, you can purchase one from shaveroutlet.com. See link below
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Norelco 3605 X... | Answered on Mar 01, 2010
i suggest you find a dealer
Norelco Health &... | Answered on Nov 24, 2019
Contact Norelco and request an assembly diagram for the 9000. Follow the diagram in reverse to disassemble.
Norelco Health &... | Answered on Jun 13, 2019
Norelco 3605 X Electric Shaver Logo
18 questions posted
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Norelco Health & Beauty
Most Popular Question
shaver replaced norelco 3605x
  • Health & Beauty
