20 Most Recent Amerock 0099689 Flat Arch Pull 96Mm Questions & Answers
How do I reverse a door handle on a hollow core door so the latch will close from the inside instead of the outside?
Most of the time all you need to do is swap the two handles and flip the latch over so the angled part of the latch is on the other side, so it will self latch when you close the door.
6/15/2018 4:42:41 AM • Amerock Hardware... • Answered on Jun 15, 2018
Deadbolt striker is a little too long. Can it be adjusted?
Have you tried calling AmerlockForLess.com for assistance? On their website they say: "American customer service reps by phone from 8:30 to 5:00 M-F. Our toll free number is 1-877-261-5805."
4/7/2018 10:00:30 PM • Amerock Hardware... • Answered on Apr 07, 2018
2answers
How to open locked security toilet loock from outside
Look for a small hole or slot on or around the handle, Push a pin inside to unlock it.
2/12/2015 3:11:30 PM • Amerock Hardware... • Answered on Feb 12, 2015
Broken key in dead bolt
If you can take the lock off the door push a small metal piece inside the lock from the back to push out the broken key. If unable to take it off, get an old windshield wiper, remove the stainless steel supports from the wiper (long skinny piece of metalt holding rubber blades in place). Grind or file an angled tooth into the end of one. Insert into lock (tooth down) so it catches on the teeht of ghe broken key, pull rod and key out.
8/29/2014 6:06:37 AM • Amerock Hardware... • Answered on Aug 29, 2014
STRIPED SCREWS IN DOOR TRYING TO REMOVE TO CHANGE LOICKS
You will have to carefully drill them out. Start with a small bit and slowly work up to a bigger one as you go once most of the head is drilled out the latch should pull off, you can then use vice grips to unscrew the remaing part of the screws.
8/11/2014 7:05:02 AM • Amerock Hardware... • Answered on Aug 11, 2014
5 inches into mm
25.4 x 5
8/11/2014 6:48:59 AM • Amerock Hardware... • Answered on Aug 11, 2014
0answers
0answers
Door handle with loose play
Remove lock from door.The round part contacting door usually spins to accommodate different width doors. This will pull the assembly together.
6/25/2014 1:37:00 PM • Amerock Hardware... • Answered on Jun 25, 2014
How can I clean/polish copper cabinet hardware
If you want to clean or polish your copper cabinet hardware, there are few way to go, like cabinet hardware (Knobs & Pulls) which you believe are copper it's really zinc casting with copper plated.on which is applied a thin coat of polish to prevent oxidation, and that plate about two atoms wide and any sort of a harsh or chemical clean on it will wipe out it. The finest thing you can follow is to take a jewelry polishing rag and go over the Cabinet hardware a bit. However, I don't see that it is offensive to have a copper pull that has turned color and has a "patina" on it. That is sometimes viewed as beneficial in decorating. The zinc pulls with copper plating are made so after few years replaced with new pulls.
5/30/2013 8:16:17 AM • Amerock Hardware... • Answered on May 30, 2013
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered on Apr 18, 2024
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Amerock 0099689 Flat Arch Pull 96Mm Logo
0 questions posted
Top Amerock Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Amerock Hardware & Accessories
Most Popular Question
clean polish copper cabinet hardware
  • Hardware & Accessories
