20 Most Recent Saniflo Sanicompact 48 Once Piece Toilet With Macerator Built Into The Questions & Answers
replace the motor control
Saniflo... | Answered on May 22, 2015
Your description sounds like plumbing from before bacteria was discovered. The output from a Saniflo macerator should be sent to a foul drain or cesspit and not a rainwater drain.
Some authorities allow local rainwater runoff into foul drains but this situation is gradually being designed out.
Could be your Saniflo installation didn't meet building regulations when it was installed. The fact it has been working fine for 2 years doesn't count for anything if it doesn't.
Saniflo Plumbing | Answered on Feb 03, 2018
I experienced this exact same issue last month. I didn't think much of it, but decided to have our residential plumber come and look at it. It turned out that our water was running constantly and that it had to be turned down some. It was a very simple fix. Now, I am not sure whether or not that is your exact issue, but you might want to adjust the levels that your water runs at. There should be a knob behind your toilet that you can twist and turn to do that. However, if that doesn't work you might have to snake it to see if there is anything wrong going on in the pipes. Plumbing Mechanical Residential
Saniflo Plumbing | Answered on Jan 04, 2016
  1. SANIFLO upflush toilet - YouTube
    ? 6:14
    www.youtube.com/watch?v=-F1v6GIbWF8
    Aug 10, 2011 - Uploaded by Regis Saragosti
    Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
Saniflo Plumbing | Answered on Jul 14, 2015
Sorry but they give you 8" for a reason, they did the testing etc. You might get by at 5" but that will probably just get by and limit the service life.
Saniflo Plumbing | Answered on Nov 27, 2014
The "tank level" switch is stuck on. You may be able to clear it by cleaning the system/pump with a water hose (outside of course) so you will have to take the system apart then give it a good cleaning. May not help but at least you will have tried.
Saniflo Plumbing | Answered on Oct 07, 2012
There is a product called Wham that works very well for this appplication.You will probably have to go to a plumbing supply outlet to find it. Just follow directions on container after you have the system clean and use monthly. It also helps with odor control. Hope this helps you. Thanks.
Saniflo Plumbing | Answered on Mar 02, 2011
Saniflo Sanicompact 48 Once Piece Toilet With Macerator Built Into The Logo
3 questions posted
Top Saniflo Plumbing Experts
Bill Johnson
Vernon Taylor
Tom Chichester
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Saniflo Plumbing
  • Saniflo Plumbing
Most Popular Question
six months ago sanicompact developed low
  • Plumbing
