You need to adjust the float. Or, you can buy the complete inexpensive float valve assembly at Lowes or Home Depot and can install it in less than 5 minutes. Turn off the water supply, drain the tank, sop up the remaining water in the tank or put a pan under the tank opening for the next step, remove the valve assembly and float and install the new valve assembly with the float included. Turn on the water supply and set the water level adjustment valve to about 1/4 inch below the stand pipe overflow drain. This is done by the float assembly. Turn on the water supply. This completes the change-out.
Your description sounds like plumbing from before bacteria was discovered. The output from a Saniflo macerator should be sent to a foul drain or cesspit and not a rainwater drain.
Some authorities allow local rainwater runoff into foul drains but this situation is gradually being designed out.
Could be your Saniflo installation didn't meet building regulations when it was installed. The fact it has been working fine for 2 years doesn't count for anything if it doesn't.
Aug 10, 2011 - Uploaded by Regis Saragosti
Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
Sorry but they give you 8" for a reason, they did the testing etc. You might get by at 5" but that will probably just get by and limit the service life.
The "tank level" switch is stuck on. You may be able to clear it by cleaning the system/pump with a water hose (outside of course) so you will have to take the system apart then give it a good cleaning. May not help but at least you will have tried.
There is a product called Wham that works very well for this appplication.You will probably have to go to a plumbing supply outlet to find it. Just follow directions on container after you have the system clean and use monthly. It also helps with odor control. Hope this helps you. Thanks.
The sound you are hearing is the check valve. Usually this valve is just above the pump. It's nothing to be concerned about, it's a normal noise, or it's the nature of the beast.
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
