20 Most Recent Norelco Quadra Action 7864XL Electric Shaver Questions & Answers
It won't turn off, what can I do?
I have the same problem!
12/24/2014 8:29:13 PM • Norelco Quadra... • Answered on Dec 24, 2014
How to replace batteriers in norelco quadra electric shaver
The rechargeable batteries are solder into the circuit board of the electric shaver. You'll have to use a soldering iron to de-solder the terminals/tabs from the PCB (printed circuit board) in order to get them out.
Then you'll need new replacement rechargeable batteries to solder back into the shaver.
You can get teh correct replacement batteries from Electric Shaver Service in Lincoln, Nebraska (if you're in the US or Canada). They even do service and repair work in about a week, if you want to have them fix your shaver for you.
Here's a link to the battery page with your shaver model's rechargeable batteries for about $15.00 (plus s&h)
http://www.electricshaverstore.com/get_item_13810334_norelco-13810334-electric-shaver-battery-set.htm
Hope you find this Very Helpful and best regards!
12/15/2014 12:10:15 PM • Norelco Quadra... • Answered on Dec 15, 2014
0answers
2answers
Won't charge
Batteries are old and probably dead. You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
12/4/2012 3:51:12 AM • Norelco Quadra... • Answered on Dec 04, 2012
2answers
My Norelco quadra action 7864
norelco quadra action 7864xl replacement heads is philips norelco HQ6 shaving heads.12_4_2012_3_47_36_am.jpg
12/4/2012 3:47:48 AM • Norelco Quadra... • Answered on Dec 04, 2012
2answers
It quit and when I
Norelco quadra action 7864xl replacement battery is norelco shaver NiCd two batteries pack.12_4_2012_3_42_33_am.jpg
12/4/2012 3:42:45 AM • Norelco Quadra... • Answered on Dec 04, 2012
2answers
I need to repalce heads
Norelco quadra action 7864xl replacement heads is philips norelco HQ6 shaving heads.12_4_2012_3_27_51_am.jpg
12/4/2012 3:28:15 AM • Norelco Quadra... • Answered on Dec 04, 2012
2answers
What replacement blades do I buy for the Norelco
You will find the correct replacement blades for Quadra shavers (except model 7800XL) at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq6-quadra-action-replacement-heads-p-250.html
9/1/2012 12:23:29 AM • Norelco Quadra... • Answered on Sep 01, 2012
2answers
Where can I purchase a new head for my norelco
You can purchase heads for model 7864XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq6-quadra-action-replacement-heads-p-250.html
8/31/2012 3:20:29 PM • Norelco Quadra... • Answered on Aug 31, 2012
The switch on my Norelco
Hi tmkilpatrick,
If you haven't already done so, I would reach out to Customer Support to see if there are any trouble-shooting steps for your issue. An agent will also be able to provide you with more information on service and repair in your specific area.
Customer Support
1-800-243-3050
Product Support Site (including Live Chat):
http://ow.ly/6sjXV
Hope this helps! Kindly rate/comment!
9/12/2011 8:05:38 PM • Norelco Quadra... • Answered on Sep 12, 2011
How do you replace the heads on a norelco quadra?
You will find a helpful video demo at shaveroutlet.com. Click on link below and scroll down for video
3/21/2011 12:57:08 AM • Norelco Quadra... • Answered on Mar 21, 2011
Battery dies 2 minutes after fully charged
This is typical symptoms of batteries that need replaced. You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
2/12/2011 4:23:29 AM • Norelco Quadra... • Answered on Feb 12, 2011
How do I change the battery?
1/30/2011 7:36:37 PM • Norelco Quadra... • Answered on Jan 30, 2011
I dropped my shaver and
you will fin a helpful video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/philips_norelco_heads_replacement
1/11/2011 1:14:40 AM • Norelco Quadra... • Answered on Jan 11, 2011
I have a Norelco 7864 XL. The razor was stuck on
this is a fairly common problem with these as they get older and plastic gets brittle. the replacement part you need is no longer available from Noreclo.
12/15/2010 4:11:09 AM • Norelco Quadra... • Answered on Dec 15, 2010
How do you remove and
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
12/12/2010 2:15:54 AM • Norelco Quadra... • Answered on Dec 12, 2010
How do I remove the cover to get to the batteries.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
10/8/2010 9:14:57 PM • Norelco Quadra... • Answered on Oct 08, 2010
How do you change the batteries
To replace, you will need to remove the back cover by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
10/1/2010 9:23:38 PM • Norelco Quadra... • Answered on Oct 01, 2010
Norelco Quadra Action 7864XL Electric Shaver Logo
36 questions posted
Top Norelco Health & Beauty Experts
Robert McClure
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Norelco Health & Beauty
Most Popular Question
charge
  • Health & Beauty
