20 Most Recent AMD Sempron LE-1150 2.0GHz Processor - 800MHz HT - 256KB L2 - 940-pin Socket AM2 (SDH1150DEBOX) Questions & Answers
0answers
Windows crash
First of all Sempron is the slowest processor you can get. Secondly this is most likely due to a driver. Does it bluescreen? What exactly is it doing, powering off? Does it give any error codes? If its simply powering off with no error it could be faulty hardware or the processor could be overheating. I would make sure you clean your heatsink with a can of compressed air to make sure its not overheating. I would first go to the motherboard manufacturer website and update all of your drivers. Also, does it boot into safemode at all? Mash F8 during boot up continually until a menu appears and try "Safe Mode with Networking". Post back the results please. Thanks
1/27/2014 8:55:03 PM • AMD Sempron... • Answered on Jan 27, 2014
4answers
How can i download AMD Sempron Le-1150 Sound Drivers
You need to know the type motherboard you have (or system) to get the correct drivers. The drivers are dependent upon the motherboard and the chipset on it, not the CPU. If you have that information, I can help you.
Cheers
7/18/2012 3:26:44 PM • AMD Sempron... • Answered on Jul 18, 2012
Can i change my processor? AMD LE-1150 to dualcore
If your using AMD LE-1150 you cant use a dualcore nor a core2duo because the socket of your motherboard is for AMD microprocessor only you can upgrade or change your procs to any AMD AM2 dual core model make sure you check the specs of your motherboard for supported CPU list. you can find that in their website
7/20/2010 11:50:50 PM • AMD Sempron... • Answered on Jul 20, 2010
How can I get User manual for AMD Desktop Motherboard AM2, DA061L-3D, 48.3BU01.01M, 09178-1M U
I would try the AMD web site. If still available, you will find one there.
6/29/2021 6:50:31 AM • AMD Computers &... • Answered on Jun 29, 2021
I just installed a motherboard because my video went out and the Onboard as well as the video card would not connect. I installed a power supply, new memory, new cpu, new hard drive, new video card and when all that failed still I installed a new motherboard. Still not connecting to the monitor. What am I missing? Here are my specifics. Upgrades Motherboard Foxconn A74ML-K AM2+ AM3 740G Motherboard AMD DDR2 MicroATX SATA PCIe x16 Phenom Video Card Dell ATI Radeon HD 4350 512MB DDR2 PCIe VGA DVI HDMI Graphics Video Card 0P002P Power Supply Apevia BT550W Beast 550W ATX Gaming Power Supply, Supports Dual/Quad Core CPUs Hard Drive Seagate BarraCuda 2TB Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache 3.5-Inch Dvd rom LG Internal 24x Super Multi with M-DISC Support DVD Burner  USB Card FebSmart PCIE 4-Ports Super Fast 5Gbps USB 3.0 Wifi adapter USB WiFi Adapter – 1200M WiFi Dongle High Speed 802.11ac 5dBi Dual Band 2.4/5GHz  Memory LEVEN DDR2 4GB (2GB×2) 800MHz PC6400 Unbuffered Non-ECC UDIMM 240 Pin CPU AMD Phenom II X3 710 2.6Ghz Processor Cpu Cooler Cooler Master CM12V Ultra Silent 8032 Fan Dimensions: 80x80x32 MM Voltage: DC 12V Speed: 2000 RPM Air Flow: 32.5 CFM Noise: 18 dBA Feature: Very Quiet & Long Life Span, Speed Sensor (Tach) Termination: 3-Pin / 3-Wire / 7.5-Inch After my new build would not boot properly I thought it was a video problem and was all ready to rma it. I specifically checked the manual for proper placement of the cmos jumper before I assembled it after reading of other peoples problems with the jumper left in the "clear" position. That's what I get for reading the manual. The jumper was actually placed correctly from the factory. The manual was wrong. -2 eggs for poor documentation and the headaches to find and fix the problem.
Perhaps the monitor is faulty? Did you check that with a device known to work. Listen to Larry though, he is the Hardware Guru here at Fixya.
4/8/2021 11:34:28 PM • AMD Computers &... • Answered on Apr 08, 2021
I have a windows 7 desktop 64bit, amd sempron LE-1200, that reads usb2.0. how do i get it to read a usb3.0 flashdrive without corrupting files when moved on it
USB 2 and 3 are the data speed capability of the interface it is possible to connect a USB3 flashdrive into a usb2 socket all that will happen is the files will transfer slower than on a usb3 socket. Hope this was helpful.
5/14/2020 11:25:53 PM • AMD Computers &... • Answered on May 14, 2020
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
3/20/2019 5:10:23 PM • AMD Computers &... • Answered on Mar 20, 2019
I have an AMD Athlon 64 X2 Dual Core processor running on Windows 7 32 bit. Can I install Windows 7 64 bit oS on this system?
yes but fresh install will be needed.back up important docs first
12/15/2018 8:53:13 PM • AMD Computers &... • Answered on Dec 15, 2018
yes you can. Win 7 win8 win 8.1 are no supported by Microsoft, only win 10.
12/15/2018 8:29:15 PM • AMD Computers &... • Answered on Dec 15, 2018
AMD Sempron LE-1150 2.0GHz Processor - 800MHz HT - 256KB L2 - 940-pin Socket AM2 (SDH1150DEBOX) Logo
11 questions posted
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
David Payne
David Payne
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AMD Computers & Internet
Most Popular Question
download amd sempron le 1150 sound
  • Computers & Internet
