20 Most Recent Koiiler XM-7676W Car Audio Amplifier Questions & Answers
0answers
0answers
I want to use this amplifier in my home. plz help
sdsadsadsdasddad
10/6/2013 4:21:23 AM • Koiiler XM-7676W... • Answered on Oct 06, 2013
My koiiler fuse is bad
you will want the one with the 40 printed on itand you can get them from 1 to 5 dollars depending where you buy on the internet
10/5/2013 6:20:10 PM • Koiiler XM-7676W... • Answered on Oct 05, 2013
0answers
0answers
3answers
Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
8/12/2010 2:28:57 PM • Koiiler XM-7676W... • Answered on Aug 12, 2010
Need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
2/28/2010 7:12:41 AM • Koiiler XM-7676W... • Answered on Feb 28, 2010
All wires are connected but i have no power to my amp.
Hello laramoe,
For the lowest resistance connection, your ground wire needs to be in good solid contact with bare metal of the vehicle frame or body within about 18-24" from the amp. The ground is probably the most important connection you'll make to the amp. A bad one will not only rob your amp of the current it needs for best performance, it could result in damage to the amp or the vehicle itself. The ground should be the FIRST connection you make, and you should spend some time making sure that it is a good one. At the absolute minimum, you should test the "resistance" between the negative battery terminal and your intended ground point. Anything above about 5 ohms and you should look for a better ground. 2-4 ohms is OK, but you'll lose some input current and that means less output. I like my meter to read 1 ohm or less, before I'm really happy with the ground connection.
You may need to pull back plastic panels and/or carpeting to get to the metal. Then, find an existing bolt or screw that goes into or through the metal (a seat bolt is good, and most trunk, hood, and many dash screws go into metal). If you are unable to find an existing screw or bolt, you can drill a hole and attach the ground with a new "self-tapping" sheet metal screw. If you do decide to drill, use a drill stop and be VERY careful around any lines or hoses. Use sandpaper or a small Dremel grinder to remove any paint, undercoating, or soundproofing materials from around the hole. Crimp the ground wire to a "ring" terminal and put a toothed lockwasher under the terminal. Make sure that the head of your screw is sized to completely surround the ring terminal and tighten it until the lockwasher bites slightly into the metal. DO NOT overtighten, or it will strip and come loose. If you wish, you can cover it with dielectric grease (like mechanics use on battery terminals) or you can seal around it with silicone. You can also spray-paint it with a corrosion resistant paint. Rust Oleum flat black works well.
Hope this helps.
6/13/2009 10:05:14 PM • Koiiler XM-7676W... • Answered on Jun 13, 2009
What size fuse does the XM 7676W Car Audio
Do not use anything bigger than a 10amp fuse. Cheaper to replace a fuse than an amp. 10 amp is usually the standard.
5/7/2009 4:49:28 PM • Koiiler XM-7676W... • Answered on May 07, 2009
My koiler car amp shuts off and gets hot. when i
Sounds like an overload...check the impedence of your speaker system and make sure that your amp is rated as stable at that impedence I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
4/12/2009 6:01:01 PM • Koiiler XM-7676W... • Answered on Apr 12, 2009
No power in amp
the fuses are ok
3/19/2009 9:49:40 PM • Koiiler XM-7676W... • Answered on Mar 19, 2009
Wet Amp
you probably too out an output on the amplifier. Will need repair.
12/25/2008 1:06:54 AM • Koiiler XM-7676W... • Answered on Dec 25, 2008
Have a manual for Koiiler XM-8787C Car Audio Amplifier?
Request the manual from Koiiler.
3/23/2021 3:53:24 AM • Koiiler Car... • Answered on Mar 23, 2021
My amps like got to much power to it a koiiler now it not coming on what's wrong not the fuses cause it's ok
Internal cercuit board over heated and got damage
7/16/2015 9:04:20 AM • Koiiler Car... • Answered on Jul 16, 2015
0answers
Replace fuse
Be the first to answer 3/12/2014 11:46:18 AM • Koiiler Car... • Posted on Mar 12, 2014Be the first to answer
I dont have aproblem with
It's only worth ~$50.
I've seen a 2000W one go for $60
2/28/2011 4:22:02 PM • Koiiler Car... • Answered on Feb 28, 2011
Koiiler XM-7676W Car Audio Amplifier Logo
17 questions posted
Top Koiiler Car Audio & Video Experts
 Francisco Mauricio...
Morne Olivier
Morne Olivier
Tom Chichester
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Koiiler Car Audio & Video
Most Popular Question
need wire diagram koiiler xm 7676
  • Car Audio & Video
