20 Most Recent
Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter Questions & Answers
Stop 7
I know Ricoh hasn't been supporting these for some time now. Do you have a set of drivers for this device?
Ricoh aficio mp 2000 can't print asking for log in username and password?
Login Issue Assistance
User
I never set any log in details, I have tried Admin,Supervisor with a blank password but not working, please assist
ChatGPT
If you're being prompted for a login username and password on your Ricoh Aficio MP 2000 printer and you haven't set any login details before, there are a few things you can try:
Default Login Credentials: The default username and password for Ricoh printers are often set to "admin" for both the username and password. Try using "admin" as both the username and password to see if it works.
Factory Reset: If the default login credentials don't work, you can try performing a factory reset on your printer. This will reset all settings, including any login information that might have been set. However, keep in mind that a factory reset will also erase any other custom settings you have configured on the printer. To perform a factory reset, you can refer to the printer's user manual or contact Ricoh support for specific instructions.
Contact Ricoh Support
Can I make my Ricoh copier not go into sleep mode?
Please increase the amount past 60 and check for an "off" option. If this does not work, please call Ricoh or reference the table of contents in your product manual for the sleep mode section. If you don't have the manual, Ricoh would be able to direct you to it. Thank you.
Ricoh 301 cannot connect with dhcp
A:If you cannot connect to the printer with DHCP, you have a few options.Connect it to a different network, perhaps one with a different DHCP server. If it connects to that one, then you know there's something wrong with the DHCP server or DHCP config on the network.Connect the printer to your computer with a USB cable and change the printer's IP address to a static one that you know works on your network and is outside of your DHCP server's range.Connect to the printer's web interface (usually at http://printerip:631) and change the network config there.
How can I fix SC 990 error in Ricoh mpc2051
the approximate meaning is that the software in your printer has attempted to perform an unexpected operation. So, if you're attempting to use a certain function on your printer, please restart and try once more. Otherwise, you might need to consult the printer manual to help troubleshoot the code.
Thank you.
RICOH PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {+1^8OOSCAMMER 69} RITA USA
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
RICOH PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {18OO*SCAMMER 69} RITA USA
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Gmail tech support pHoNe {1^84424O9lI1~} nUmBer
Gmail tech support phone {+1^84424O^9lI1} nUmBeR
