20 Most Recent Onan Cummins 4.0 KY-FA/26100 RV QG 4000 4000K Gasoline Generator Micro Questions & Answers
2answers
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again. If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
3/24/2018 7:33:35 AM • Onan Cummins 4.0... • Answered on Mar 24, 2018
Why does it run only in the start position?
Hello Martin, Your generator might have a low oil pressure shutdown switch. First check the oil level. If oil level is low, fill oil to proper level. If oil level is fine, I would install an auxiliary oil pressure gauge . If oil pressure is normal, I would change the oil sender unit. If oil pressure is low, I would change the oil pump.
8/3/2015 9:32:08 PM • Onan Cummins 4.0... • Answered on Aug 03, 2015
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
7/23/2015 3:26:00 PM • Onan Cummins 4.0... • Answered on Jul 23, 2015
When I push the start button, why does it just click?
Hi John: Sounds like you may have a bad starter. Can you bench test it?
7/11/2015 3:47:18 PM • Onan Cummins 4.0... • Answered on Jul 11, 2015
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
11/17/2013 8:21:58 PM • Onan Cummins 4.0... • Answered on Nov 17, 2013
Wont stay running
if it stops running after you let your finger off the start switch, check the rotor, rotor brushes slip rings for cleanliness. Check all wiring plugs back to the control board for tightness. The control requires a feedback from the stator, if it doesn't see it, it will shutdown. If all that checks, have someone ohm the stator windings. Then it;s your control board most likely
11/15/2013 10:43:57 PM • Onan Cummins 4.0... • Answered on Nov 15, 2013
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty. You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
11/15/2013 10:40:09 PM • Onan Cummins 4.0... • Answered on Nov 15, 2013
I know that issue with oil usage is due to Reed valve stuck open ,but I was hoping that someone could provide me with a picture that showed the correct position that the reed valve needs to be.
I can provide you with a picture, can you post and email?FYI it is seldom the reed valve, but it can cause it. How old is the unit?
11/15/2013 10:34:09 PM • Onan Cummins 4.0... • Answered on Nov 15, 2013
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
11/15/2013 10:17:12 PM • Onan Cummins 4.0... • Answered on Nov 15, 2013
I can't find mine, where are thayclean spark
It is a screen on the muffler output, also remove the plug on the bottom of the muffler to remove carbon
2/19/2015 12:52:20 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan 4000 not charging battery
Some Onan 4KW do not have auxiliary battery charge windings and rectifier. Are you sure you have one? If not you will need and external charger
2/19/2015 12:50:20 PM • Onan Electrical... • Answered on Feb 19, 2015
Generator runs fine but quits producing power
Model spec number? be more specific please
2/19/2015 12:49:08 PM • Onan Electrical... • Answered on Feb 19, 2015
What the compression to be on a 2 cylinder onan motor?
Which motor, which generator model and Spec
2/19/2015 12:47:49 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan 12hdkcd error 27 and 13
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
2/19/2015 12:47:03 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan 2500 camp power ran fine then died & aslong as i held starter switch on it ran fine but stopped when released start switch . after a few days it started up & ran fine for about 30 min. t
You may have dirty rotor slip rings, or bad brushes. Field voltage must be maintained. Check those first
2/19/2015 12:43:02 PM • Onan Electrical... • Answered on Feb 19, 2015
Rv onan rv runs but now makes a rackett when running was real quiet
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
2/19/2015 12:41:51 PM • Onan Electrical... • Answered on Feb 19, 2015
Idle surges
What model? Please be more specific.
2/19/2015 12:37:34 PM • Onan Electrical... • Answered on Feb 19, 2015
Onan Cummins 4.0 KY-FA/26100 RV QG 4000 4000K Gasoline Generator Micro Logo
16 questions posted
Top Onan Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Onan Electrical Supplies
Most Popular Question
will run only in start position
  • Electrical Supplies
