20 Most Recent
CorelDRAW® Graphics Suite X3 Upgrade Version for PC Questions & Answers
When i install coreldraw it
try to check the system requirements for the corel draw to your cpu, probably it wont fit the required system, also consider to off the firewall just to make sure that it wont block the program.
Hope it helps thanks.
Can not instal corel x5
dear for install coral draw x5 you have need install xp sp3 its must you can download it from Microsoft site free . for more info check on google
best of luck
After installing new. In full editor mode the
Welcome to Fixya. If the system is or the program is not responding would it be possible for you to open Task Manager and check the CPU Usage of you computer before and after you open CorelDraw. And if possible turn off the other progams that is running on the computer that your not using. If the system is using 100% then most likely it would freeze and the program might not respond and the operating system aswell.
To open
Task Manager by pressing
Ctrl + Alt + Delete or
Ctrl + Shift + Esc on your Keyboard.
How to Disable Unwanted Running Programs
Go to
Start then
Run type
MSCONFIG
Click on
Startup and disable the programs that you are not using.
And also download and install the file that corel sent you. If you have questions just let me know.
Thanks for using Fixya.
I'm having problem with my color palette, my cmyk
very easy,
go to TOOLS>Color Management>(down left)>Style>Optimized for professional output or Optimized for desktop printing. (In many cases this is the first).
...I hope you solve the problem
Ivanhoo
CorelDRAW serial no
This is illegal. Please buy this product.
I gave this answer for your best. Because with an illegal key you will not be able to download updates & get support.
Additionally you make a crime.
I am using Corel X3 version and would like to open
Step 1
Launch CorelDRAW Graphics Suite X4. If you don't own the software, download and install a free 30-day trial from Corel.
Step 2
Go to "File" "Open" and open the X4 file you want to convert into a backward-compatible X3 file.
Step 3
Go to "File" "Save As" and choose "CorelDRAW X3-compatible" from the "Save as Type" drop-down menu. Click "Save."
Print icon is greyed out
Check for any printer has been configured on the system, if not install/configure the same will solve your problem.
Revert back for more clarifications or assistance required.
12/15/2009 10:18:07 PM •
CorelDRAW®...
Answered
on Dec 15, 2009
