20 Most Recent Computer Associates CA Internet Security Suite Plus 2008 (ISSP08STDW03) Questions & Answers
Hoping for help Receiving 'casc.exe error
Kaspersky is better
4/23/2017 8:12:10 PM • Computer... • Answered on Apr 23, 2017
Once i downloaded and installed CA 2010 Security
you can fix this problem through this way
1. Edit the Host File (all the steps explained below) (check if you are able to connect to internet in safe mode with networking ...if not proceed to 2nd step)
2. Change Proxy Settings (if you're still unable to connect to net)
Reimage works by comparing each and every OS system files with the correct files from a web repository of 25 million Windows components. (since Reimage works by comparing with correct file, it can easily find the hiding rootkit, infact this is what a rootkit remover do......dumps a list of files from your hard disk drive and compares it with the list from the recovery console in order to find a hiding virus) This is the sole reason you can get a PC as good as new once you run Reimage, all other antivirus and antimalware programs just delete the virus....but they don't correct the damage...which results in re-infection and slow performing PC.
Reimage first scans your computer thoroughly; all the files, folders, registry keys and values, drivers, softwares, stacks and then either repair or remove those stuffs that should be there. But it's not just that it does. They have an enormous web repository of application, drivers, system objects, etc. from where they compare your PC's files and if corrupted replace it with the healthy ones.
The problem here is Security Suite virus changed the HOSTS File, or changed Proxy Settings.
1. Mend Hosts file: The HOSTS file is used to translate a host name to an IP (Internet Protocol) address without querying the DNS (Domain Name System) server. In general if you know the host name of the machine that serves the unwanted content, you can redirect it to 127.0.0.1, which is the local IP address of your machine.
For example, assume you have redirected the ad.doubleclick.net ad server to 127.0.0.1. Every time your browser tries to load an image or a flash animation from the ad.doubleclick.net ad server, it will be redirected to your machine instead.
As a result, the browser will not be able to show any content from this ad server. The same message appears when a web site is unavailable for other reasons that HOSTS file blocking. The HOSTS file is named 'hosts' and editable with any text editor, such as Notepad or Wordpad.
The file generally appears at: •'C:\Windows\System32\Drivers\Etc\hosts' on Windows XP
Before editing, backup the current HOSTS file. You need to delete all the lines from this hosts file except "127.0.0.1 localhost".
The other entires you saw there need to be removed as they are malicious. (This is why IE unable to connect, because the HOSTS file block the huge list of websites...and you get a warning that "The Page cannot be displayed") After removing the entries from hosts file, please save this file and close it. Now you should be able to search on Google. If not,
2. Change Proxy Settings: Start your PC in safe mode with networking, If you can`t run the IE, then you should repair the proxy settings of Internet Explorer. Run Internet Explorer, Click Tools -> Internet Options. Select Connections Tab and click to Lan Settings button. Uncheck "Use a proxy server" box. Click OK. Click Apply. Click OK. And go to http://reimagepcrepair.com/ to run a Scan.
But one of my subscriber mailed this " But after I unchecked use a proxy server, and then ok, Apply was not an option to click. Another idea?"
So am giving you more options...
1. Run Internet Explorer, Click Tools -> Internet Options
2. Select Connections Tab and click to Lan Settings button
3. Click Advanced button to open Proxy settings. Copy and paste the following text into "Do not use proxy server for addresses beginning with:" go.trendmicro.com;pcfixeasy.blogspot.com;reimagepcrepair.com; (whatever list of web address you would like to use)
4. Click OK to save Proxy settings, then Click OK to close Lan Settings and Click OK to close Internet Explorer settings. (Now you should be able to click 'ok')
5. Download HijackThis. NOTE: before saving it onto your computer rename HijackThis.exe to iexplore.exe
6. Double click renamed iexplore.exe. Then click "Do a system scan only" button and look for similar entries in the scan results as shown below:
R1 – HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1
O4 – HKLM\..\Run: [{RANDOM}] C:\Documents and Settings\Username\Local Settings\Application Data\{RANDOM}\{RANDOM}shdw.exe
O4 – HKCU\..\Run: [{RANDOM}] C:\Documents and Settings\Username\Local Settings\Application Data\{RANDOM}\{RANDOM}shdw.exe
7. Once you have selected all entries, close all running programs then click once on the "Fix checked" button. Close HijackThis.
8. Go to http://reimagepcrepair.com/ and run a scan
7/28/2015 5:56:42 AM • Computer... • Answered on Jul 28, 2015
How can i unlock my winrar file
This could mean that the file you are attempting to open is password protected the only way to open it is with the password
9/3/2012 7:17:47 AM • Computer... • Answered on Sep 03, 2012
0answers
2answers
Casc.exe give me an error
You're probably running the 2008 or 2009 version of their software.
Get the _free_ upgrade to the 2011 (or 2010) version of their software, and install it,
to make the C(omputer) A(ssociates) S(ystem) C(entre)
work properly.
3/17/2011 7:28:30 PM • Computer... • Answered on Mar 17, 2011
Why when i turn on the computer this comes up -
Go to Run(In start menu) and type msconfig and press enter. A new window will open up. Go to Statup...There will be a big list of files. look for the one have casc.exe name... and then just uncheck it. Click OK, it will ask for restart. then restart your PC. When the computer will start again it will show you a message. Just check "Don't show me this again" and click OK.
Have a nice day :)
11/8/2010 2:52:57 AM • Computer... • Answered on Nov 08, 2010
2answers
I would to follow YouTube's directions for
This was quite simple to find and even answered my own question of a similar nature LOL
All it means (cryptic) is that the index data is in the wrong place
http://www.google.com/support/forum/p/youtube/thread?tid=785123aacac09508&hl=en
See REPLY number 4.
It worked a treat for me
Bob
9/12/2010 10:06:04 PM • Computer... • Answered on Sep 12, 2010
Could you please tell me the exact link for
Welcome to FixYa
Here is the Link for 1 year Free Licence Key Click here
Resend Free Licence Key Link Click here[in case of For got /Not Received mail including Registration Key]
Note: if you cant get/See Received mail including Registration Key-you may have to Check in Spam/Junk folder in your Mail Box...
Hope this HELPED you...Thanks for Contacting FixYa...
6/26/2010 1:23:49 PM • Computer... • Answered on Jun 26, 2010
How to break out k9 web protection alert in my
Simple=ask your parents!
4/21/2010 11:30:05 PM • Computer... • Answered on Apr 21, 2010
How do I cancel a CA Internet Security subscription.
SPEAKING WITH MY EXPERIENCE: Either try Security Essentials from Microsoft OR Avast. There’s free software out there to try.
Helpful Free Software below Read On.
FREE SPYWARE
Download Spybot Search & Destroy. Restart computer, then run Spybot to see what spyware comes up, AND DELET IT.
FYI---Virus Protection-- 2 programs of virus protection will conflict with each other and will actually cancel out the protection. SO just download one.
Running Spybot Search & Destroy with EITHER Avast or Avg (great Free virus protection programs ) will keep a computer in good working condition. FREE
HERE ARE SOME LINKS, THAT WOULD BE BETTER:
Avira AntiVir
http://www.free-av.com/
NEW *****Somthing new FROM MICROSOFT.*** 2009 ---Security Essentials
http://www.microsoft.com
Pop up Blocker ** free******
www.panicware.com
*****Spybot - Search & Destroy 1.5.2 ****
FREE SPYWARE
http://www.download.com/Spybot-Search-De…
****Avast ***FREE ANTI VIRUS PROGRAM
http://www.avast.com/eng/home-registrati…
****AVG ****FREE SPYWARE PROGRAM
http://www.free.avg.com
**Ccleaner*** FREE
http://www.download.com/3120-20_4.html?q…
***Malware**** FREE
http://www.malwarebytes.org/.
$ *** KASPERSKY ***
http://www.kaspersky.com
There are alot of $ anti-virus and Internet security programs out there,
ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 ,
I feel that is the best for your money.
REMEMBER TO KEEP UP THE DAILY MAINTENANCE ON ALL OF YOUR COMPUTERS.!
Good Luck. If you think this is good information, , please rate me.
4/14/2010 11:25:52 PM • Computer... • Answered on Apr 14, 2010
CA suite downloaded & crashed my computer
Get rid of CA Internet Security. It is normally for 1 year anyway. This CA should have expired already, if you did not purchase the 2 yrs.
There are alot Free Programs out there Better.
Read below.
Go to www.trendmicro.com, and do the free scan Trend Micro's House Call virus, spyware and malware scanner and cleaner. http://housecall.trendmicro.com
If you have anything, remove them. Helpful Free Software below Read On.
FREE SPYWARE
Avira AntiVir – Free Anti-Virus Protection
FROM MICROSOFT 2009 -Free --Security Essentials
Pop up Blocker- free
www.panicware.com
Spybot - Search & Destroy 1.5.2 -FREE SPYWARE
Avast- FREE ANTI VIRUS PROGRAM
AVG- FREE SPYWARE PROGRAM
Ccleaner- FREE
Malware- FREE
$ *** KASPERSKY ***
There are alot of $ anti-virus and Internet security programs out there-ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 , I feel that is the best for your money.
If all else fails, then do a Reformat. You will loose everything, so do a Back-up.
Good Luck.
4/4/2010 5:09:21 AM • Computer... • Answered on Apr 04, 2010
How do u get facebook on a blocked college
First, there is a simple way and it will rely upon how your school?s privacy settings are set up. If they set up the settings with net Explorer, then there?s a good chance that they won?t effect you if you use different web browser. You can use Mozilla Firefox, Opera, or another net browser and you could be able to access Myspace, Facebook, Hi5, and lots of other sites that were blocked when you used web explorer. This is the simplest way to unblock myspace, so try it first. When this doesn?t work, then you know your personal computer folks are good and they have blocked it regardless of which browser you use. There?s another way, though. Second, you can use what is called a proxy web server. This is basically a site that is set up to act like the face for your perusing. When you go to an internet site through a proxy web server you are essentially not using your school?s servers so you won?t be blocked from viewing a site the college has blocked. This is the best way to find a way around the block and use Myspace and other sites in school.
4/1/2010 11:06:00 AM • Computer... • Answered on Apr 01, 2010
I lost my license key is there a way i can get it?
You can contact the manufacturer. Once you provide proof of purchase they should be able to furnish you with a new key.
3/16/2010 2:20:56 AM • Computer... • Answered on Mar 16, 2010
2answers
Security Suite Plus 2008 blocks
This is one of the worst trojans to remove because it basically hijacks the antivirus and computer options, such as add/remove, control panel, etc.
To rid of this rogue, I use Spyunter from Engima. It has proven very reliable as I use it for my business. It does cost a small fee of $39.99 but will clean the computer out. Most free software such as malwarebytes, hijack this, etc. are great for the small malware but this one needs requires a powerful tool to remove.
http://www.enigmasoftware.com/
It takes 20 minutes to scan and 5 to clean and all problems are gone!
You can download it free but you will need to purchase before you can remove them all from computer.
This security suite is also compatible with any current antivirus software you have on the computer so you will not need to uninstall anything before downloading it.
I do recommend you purchase on a safe computer and not the infected computer. You can download the software from the infected computer and install though.
Once the culprit is gone, everything will work again on the compuetr as it will no longer be hijacked.
Hope this helps!
12/10/2009 12:19:57 AM • Computer... • Answered on Dec 10, 2009
I forgot my password can anyone help me
yes but will need more info to do so if its the pw that u use tologin with then all u have to do is remove the jumper pin and then replace it inside the system it are small and in a corner ...usally
12/8/2009 12:27:10 AM • Computer... • Answered on Dec 08, 2009
A popup blocker is preventing me from downloading
Open your internet explorer ,Click tools and turn off the pop up blocker until you finished with the link,then just re enable
10/1/2009 3:19:28 PM • Computer... • Answered on Oct 01, 2009
Windows Security won't reconnize my CA Security
Windows does not recognise the software is all. Just turn off the warning in windows control panel.
BTW. Anti virus is a waste of money, a big rip off, you have to visit very dodge sites & download strange looking files to do this. Anyone who is web savey & not a total pervert has no need to worry about viruses. Windows has a decent firewall built in & if you use a router then that probably a firewall too. Any more is overkill & will just slow down your system. So firewall yes but what you have is fine. AV. Get rid of it.
7/19/2009 7:37:56 PM • Computer... • Answered on Jul 19, 2009
Cannot connect to software update database.
Um have your thought of calling for support?
Or try uninstalling it and reinstalling it never know with software.
Computer Associated has a pretty good support section. take a look and you will get your software working properly.
Computer Associates Support
5/22/2009 4:05:26 AM • Computer... • Answered on May 22, 2009
Shield Tray Icon does not show
go here
C:\Program Files\CA\CA Internet Security Suite\cctray
and click on cctray.exe and the icon should be back
4/17/2009 4:05:15 AM • Computer... • Answered on Apr 17, 2009
Computer Associates CA Internet Security Suite Plus 2008 (ISSP08STDW03) Logo
32 questions posted
Top Computer Associates Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
k24674
ADMIN Eric
ADMIN Eric
Are you a Computer Associates Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Computer Associates Computers & Internet
Most Popular Question
follow youtubes directions
  • Computers & Internet
