20 Most Recent Gentron 10,000W Generator with Electric Start - Gentron Questions & Answers
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
3/9/2016 12:55:07 AM • Gentron 10,000W... • Answered on Mar 09, 2016
Try this again. Starter works fine, checked fuel line,sprk plg and cln carb, just doesnt fire
Try checking your oil sensor. These are common problem areas that will shut your generator down, and prevent it from starting.
3/9/2016 12:47:15 AM • Gentron 10,000W... • Answered on Mar 09, 2016
How do I wire the on/off switch on a gentron 10,000 generator?
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/ Generator Guru
10/2/2015 1:33:33 PM • Gentron 10,000W... • Answered on Oct 02, 2015
Gentron gg3502d outlets have no power
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
6/24/2014 11:20:22 AM • Gentron 10,000W... • Answered on Jun 24, 2014
Outlets providing incorrect voltage
The Wiring for this unit was screwed up in manufacturing. reverse the lines from the 120 side and the 120v end of the 240 pole. that should resolve the issue and you should also find that if you trace the wires back to the source on the dynamo they will now match/Pair up properly. Make sure to mark the wires you are swapping carefully and test under no load before load testing the unit.
11/21/2013 8:35:27 PM • Gentron 10,000W... • Answered on Nov 21, 2013
0answers
Gentron GG10020 Generator doesn't start news.
No that is definitely not good news is it! All the reasons of what causes the bad news https://www.google.com/search?q=Gentron+GG10020+Generator+doesn%27t+start ..
2/19/2024 12:21:58 AM • Gentron... • Answered on Feb 19, 2024
Gentron 10,000 watt generator, 2013 GG10020 is throwing out white plastic chips during running at the engine/pull starter end.
Sounds like pieces of the flywheel fins-if they are plastic. Some are.
10/11/2020 9:36:34 PM • Gentron... • Answered on Oct 11, 2020
Gentron pro2 7500w generator no voltage to carburetor solenoid
The anti-afterfire solenoid is typically powered from battery when the ignition switch is in run or start position. If yours has two wires, one goes to frame ground and the other to the ignition switch.
10/29/2019 12:38:25 AM • Gentron... • Answered on Oct 29, 2019
My Amana washer won't turn on after the power was shut off for trying to use a generator cuz we have a gentron in the house but it still won't turn on can anyone help me
Please ask your supplier for help, i think it is fast to solve the problem. If you need Cummins genset or Perkins genset, please visit website: www.dieselgeneratortech.com.
10/15/2019 3:28:28 AM • Gentron... • Answered on Oct 15, 2019
Gentron 6000 watt propane generator
Hi! We have a put together a guide here to assist you in these situations. It will guide you through testing, repairing and finding any parts you might need for the Generator. : https://www.generatorguru.com/need-help/ Regards,The Generator Guru Team
8/3/2018 1:47:24 PM • Gentron... • Answered on Aug 03, 2018
The start toggle switch has gone bad on my Gentron generator gg10020 Where can I get a new switch
We hold the switch you need :) https://www.generatorguru.com/gg10020-gg10020c-1/?sort=featured
8/3/2018 1:19:11 PM • Gentron... • Answered on Aug 03, 2018
Can the oil stay in my Gentron 10,000 watt generator for any length of time? Or do I need to drain it every time even if I only use it for an hour?
You change the oil after used for a certain period of time. If not used often you do not change the oil as often as in a car. The manual you have will give you so called recommended intervals which in most cases are a tad too often.
9/4/2017 1:11:27 AM • Gentron... • Answered on Sep 04, 2017
Gentron 10,000W Generator with Electric Start - Gentron Logo
11 questions posted
Top Gentron Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
CJ Rock
CJ Rock
Are you a Gentron Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gentron Electrical Supplies
Most Popular Question
wiring diagram g g 10020 gentry
  • Electrical Supplies
