20 Most Recent Kole audio Q2-1920 Car Audio Amplifier Questions & Answers
The Amp Is Most Likely In Protection Mode... 2 Ways To Figure Out Whats Wrong With it Is Check Every Single Wire And Make Sure That Every thing Is Hooked Up Correct And There Are No Bad Connections With Ur Remote Wire, Ground Wire, And Battery 12v Wire, Rca Cables As Well. If Every Thing Checks Out Good Then Try Checking The Fuses And Make Sure u Are Using The Correct Fuses That Are Good For That Amp. If U try These 2 Things And You No Your Subs Are Hooked Up Correctly Then The Worst Is Probably There. I Had The Pioneer 7200 Amp And It was A Blown Amp And The Red Light was Constantly On. No Sound No Nothing. If U Try Those Steps And it Still Does Not Work Then Most likely Your Amplifier Is Toast. Hope This Helps :-)
Kole audio... | Answered on Feb 18, 2011
chenge and replace the safe of the amp
Kole audio... | Answered on Jan 16, 2008
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
Kole audio Car... | Answered on Jul 01, 2015
I re-wrote your question and I put you in the right Category :>)
Your unit, only available FROM Japan, and as Larry says many are for the Japanese home market only, and a sold ONLY in Japanese language.
Your unit
https://www.nengun.com/clarion/av-integrated-memory-navigation-nx710-897085
There is help here
Car Electronics Technician: Russell H.
The question about the problem, with a GPS or stereo device in a car, that turns out to have an interface in Japanese is, whether the car it is in was intended for the Japanese market.
Generally, in a car that was intended to be sold in Japan, the language in the included devices is in Japanese and has no capability to switch language, unfortunately. Is it possible that your car is indeed an intended-for-Japanese-market car?
I am looking up the info on changing the language for that model, if it is possible. I will post later with that information, if I can find it.
Try this:
On the main screen, touch the triangle with the gear icon.
Then the first entry should be the System Language (no matter what it looks like in Japanese kanji, it should be at the top of the gear-icon Settings screen.)
Touch the language displayed there (whatever it looks like) and see whether there is any choice that looks like
English
If none of the language choices are in anything but Japanese kanji characters, then you may have to work through each choice, seeing whether it changes the interface to something else than Japanese kanji characters, until you hit upon one that matches what you need... regrettably there may be no other practical way of getting to the objective here.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01psddnS7TgS3hZNjVHYFzT-FDO0A%3A1610557271600&ei=Vyf_X-j7I4Gk5NoPy9aPuAI&q=clarion+nx710+change+language
You can also use a Smartphone and with the Google Translation app, use the Camera feature to translate what you are seeing. Look for Settings - Language
Car Audio &... | Answered 3 days ago
I would assume this is 1000W peak-to-peak, so divide by 2.83 = 350 rms, or 88W rms per channel.
See link for bridging information:
Car Audio &... | Answered on Jan 10, 2021
Need to know which wire gose where
Car Audio &... | Answered on Jan 04, 2021
Pull straight out on knob.
Car Audio &... | Answered on Dec 30, 2020
Kole audio Q2-1920 Car Audio Amplifier Logo
3 questions posted
Top Kole audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kole audio Car Audio & Video
Most Popular Question
light red
  • Car Audio & Video
