20 Most Recent Kole audio QX2-1920 Car Audio Amplifier Questions & Answers
Hi so what are you saying does it work when you put pos on pos and neg on neg more info please the more the better
Kole audio... | Answered on Oct 17, 2009
Make sure you run the Positive wire from battery on one side,which is normaly the drivers side. Then run the remote wire and the spearkers on the passininger side. Feedback comes from two places, Your radio or your amplifiers. If running to amps always run sepert positive wires with 25amp fuses on each. For the ground (8g) and power wires are always best at 4g or 8g wiring. The ground wire must go to a clean spot of metal that is ether the frame or chasey of the car. Plus use metal srew to mount the ground wire. If it is not giving you feedback then thats a good ground which is ok to mount 2 or 3 amps max. If you still hear feedback, it's time to look at the radio and make sure the ground wire is good.
Kole audio... | Answered on Jun 21, 2009
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
Kole audio Car... | Answered on Jul 01, 2015
Most of the generic electronic components are simply purchased by RS and packaged to sell in their stores. In the last few years, there have been more items 'custom manufactured for radio shack' that you won't see elsewhere. I don't believe Radio Shack manufactures them. The items are produced by manufacturers who are capable of supplying whatever is needed.
For a more definitive answer, you should contact Radio Shack.
Car Audio &... | Answered 16 hours ago
https://www.timescar-rental.com/en/beginner/gps.html
Car Audio &... | Answered 24 hours ago
https://www.manualslib.com/manual/360975/Panasonic-Strada-Cn-Nvd905u.html
https://www.manualslib.com/manual/1392340/Panasonic-Strada-Cn-Nvd905u.html
Visit these sites. You can download user manual, as well as service manual of the set, from these sites. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Car Audio &... | Answered 2 days ago
There are lots of websites out there that specialise in radio unlock codes. Have you tried some of the Rover Owners Forums? They might be able to supply you with it. Most websites will charge a fee for the service but it usually isn't a big cost.
Car Audio &... | Answered on Mar 05, 2021
Please check on this link: https://www.google.com/search?q=What+is+best+way+to+unlock+front+panel+Kenwood+DPX-U5120&source=lmns&bih=625&biw=1349&rlz=1C1CHBD_enPH898PH898&hl=en&sa=X&ved=2ahUKEwjwmerD3ZbvAhXBFnIKHcFFA70Q_AUoAHoECAEQAA
Car Audio &... | Answered on Mar 04, 2021
Your local dealership will provide the code for free, but you have to produce the Registration document showing the VIN Number, otherwise they may be helping you with a stolen radio.
Or
There are sites that sell you the code based on the serial number. There are sites that SAY are FREE, but they aren't. Typical cost is around $18 USD
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00seDOo_WUsy4rlr1a83BXw8YDnBQ%3A1614104298677&ei=6kY1YNHnKMi7gge6hrPYBg&q=renault+radio+code
Car Audio &... | Answered on Feb 27, 2021
Car Audio & Video Logo
2 questions posted
Top Kole audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kole audio Car Audio & Video
Most Popular Question
improperly hooked ground connection
  • Car Audio & Video
