20 Most Recent Lanzar Vibe 1200D Car Audio Amplifier Questions & Answers
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Lanzar Vibe... • Answered on Dec 18, 2014
make sure your ground is drilled threw thick metal and the paint is scraped off and make sure that all the wires connecting the amp are 4 gauge or higher and if that doesn't do the trick get a better amp that can throw more power
connect the red wire of the amp to a car battery (+). the black to a car metal and the remote cable to the blue wire in radio. when you turn on the radio the amp turn of--when you turn off the radio the amp turn off.
Lanzar Vibe... • Answered on Aug 29, 2011
overheating. may not have enough power supply. install capacitor
Lanzar Vibe... • Answered on Mar 29, 2010
Depends on if your using it for a sub,or in inside.i can help you hook it up give me some specs on your equipment.and what your using it for.
Lanzar Vibe... • Answered on Nov 07, 2009
When an amplifier causes trouble or otherwise stops working, it is necessary to eliminate external possibilities such as a short circuited output. If nothing external is causing the problem, unless you have a good friend who is an electronics engineer, it will be a repair shop task...
Lanzar Car Audio... • Answered on Apr 27, 2020
Check your fuses. Check to see if any of the wires are loose. Could be a blown fuse or loose wire. Possibly the following link might be of interest: https://www.youtube.com/watch?v=xMbsieEj0UM
Lanzar Car Audio... • Answered on Mar 15, 2019
have diagram of any sort?
Lanzar Car Audio... • Answered on Jan 12, 2018
Lanzar Vibe 1200D Car Audio Amplifier Logo
Popular Tags
6 questions posted
Top Lanzar Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lanzar Car Audio & Video
Most Popular Question
protection light comes
  • Car Audio & Video
