20 Most Recent Astoria Argenta SAE/JUN Espresso Machine Questions & Answers
Leaking from unerneath
YOU HAVE TO OPEN THE TOP TO SEE WHERE THE LEAK COME FROM, OVERPRESSURE VALVE, CONNECTIONS TO BOILER , O-RINGS, SEALS, SENSORS CONNECTED TO THE BOILER ETC. U CANNOT TELL FROM THE BOTTOM!! RUDY.KY
1/3/2018 4:04:09 PM • Astoria Argenta... • Answered on Jan 03, 2018
Keurig b70 tripping circuit
Could be the breaker does not match up with the required amperage for the machine or you could be grounding out somewhere inside the machine.
www.kaldi.com
1/23/2011 3:50:52 PM • Astoria Argenta... • Answered on Jan 23, 2011
Looking 2 reinstate the electronic missing parts so it sautomatic
Yes the autofill is inside the control electronic box . If you know about electronic PCB board you migh need to replace a relay which is welded on the PCB board. Or you have toreplace the whole electronic contraol box which is expensive.
Please remember to vote for a rating for this answer, thanks
2/17/2010 7:20:27 PM • Astoria Argenta... • Answered on Feb 17, 2010
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
7/16/2009 5:01:12 PM • Astoria Argenta... • Answered on Jul 16, 2009
2answers
We Have an Astoria SAE 2 Group and am looking to
On the right side of the machine next to the serial number is the most likely spot for the NSF sticker or tag depending on the model of the machine it may only have an ETL listing.
7/16/2009 4:47:40 PM • Astoria Argenta... • Answered on Jul 16, 2009
I have an Astoria Argenta SAE1 Jun espresso
Your problem could be one or two items (element or pressure stat or both). Remove the screw in the top of the P.stat(black or gray rectangle box with electrical wire going in from bottom about 4-6 inches long), lift the cover and check the terminals(turn power off). Make sure that there are no loose connections on the terminals.
On the element remove the wires that are connected to it and test with an Ohmsmeter.
5/30/2009 12:49:30 AM • Astoria Argenta... • Answered on May 30, 2009
Cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
5/28/2009 11:55:28 PM • Astoria Argenta... • Answered on May 28, 2009
Will not dispense water
If you're pump is working and your needle shows around 9 bars when running, most likely your Solenoid valve is bad. This can be caused from improper backflushing among other things.
We stock them ($60). Email me at [email protected] with your contact information or from our website www.kaldi.com
Alex
2/13/2009 12:17:49 AM • Astoria Argenta... • Answered on Feb 13, 2009
Asotoria model aep12n - do I have to use a water softener?
You can use it without one but it would be best to install a water softener system like an everpure ql3 head with a 7S0 softener. That might run you about $200 installed.
4/5/2014 1:18:01 PM • Astoria Argenta... • Answered on Apr 05, 2014
How do i reset the program for an Astoria Sibilla SAE-3 back to factory settings.
Jason, have you tried cutting power off to the machine for 5 minutes?
5/12/2023 10:47:31 PM • Astoria Coffee... • Answered on May 12, 2023
Astoria Tanya not working after programming.
notify manufacturer or return it
2/1/2022 12:40:48 PM • Astoria Coffee... • Answered on Feb 01, 2022
Jus got an astoria sae junior i got hot water steam but no water on brew head no boiler pressure is 0 all the time just change the pump need help
There could be a number of issues here. If the pump pressure reads 0 then that would suggest there is no power going to the pump. Does the machine hum when you press for a brew? If it does then the pump is receiving power. If you have changed the pump recently have you reset the pump pressure manually on the pump head? This is done by adjusting the nut (12mm I think?) anti-clockwise to increase the pressure. Clockwise to reduce it. Perhaps the pressure gauge is faulty? No water to the brew head if the water pressure is fine and the pump is working indicates a blockage in the group head. You will need to strip down the valve and clear the filter which is a small hole under the large nut... Make sure the water is turned off and the machine is cold and isolated before stripping out the valve.
10/3/2018 11:47:19 AM • Astoria Coffee... • Answered on Oct 03, 2018
Astoria Divina SAE/2N 2 heads. What would make the spout in between the heads be only cold water and the water level gauge shows all the way at the top of the glass?
If by spout you mean tea valve, it could be that the economizer mixing solenoid valve is set to deliver more cold water when mixing. As for the level the silver probe on boiler.
3/4/2018 1:17:44 PM • Astoria Coffee... • Answered on Mar 04, 2018
Astoria Argenta SAE/JUN Espresso Machine Logo
12 questions posted
Top Astoria Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
john h
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Argenta Astoria
  • Argenta Astoria
Most Popular Question
cannot turn off flashing lights buttons
  • Coffee Makers & Espresso Machines
