20 Most Recent
Andis Styliner SLII Hair Trimmer Questions & Answers
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Loud
There is a power management mechanism on the side opposite of the power switch that looks like a circle with a **** in it. To set this to the optimum setting, plug the trimmers in and cut it on. Next, your going to use a flat head screwdriver to turn the knob clockwise until it clatters continuously. Next, you turn the know back in the other direction slowly until the clattering stops altogether. Now, the "noise" should be gone and your trimmers are set to perform as they did when you first bought them.
