20 Most Recent Andis AGC2 Hair Trimmer Questions & Answers
If the latch has been pushed down without a blade on it you will need to get a flat head screw driver. Push up the blade lock and put the screwdriver behind the the tongue on the hinge. While pushing up on the latch push the tongue out with the screw driver. If you need any add'l assistance please call the Andis customer service dept at 1-800-558-9441.
Andis AGC2 Hair... | Answered on Aug 18, 2014
put a flat bladed screwdriver under the part of the hinge with two ridges on and pull it up.
Andis AGC2 Hair... | Answered on Aug 14, 2014
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
Andis AGC2 Hair... | Answered on Jun 24, 2014
Sounds as though the switch is faulty on the circuit board you can purchase new Andis parts here Dog Clippers
If you look at the base of the blade at the bottom edge the is a black metal bar, push this in towards the blade and pull the nose of the blade away from the clipper.
Andis AGC2 Hair... | Answered on Jun 05, 2014
try replacing the blade drive assembly they wear in width.
Andis AGC2 Hair... | Answered on May 08, 2014
This round cylinder is a permenant magnet and doesn't actually connect to anything, the only contact which matter are the copper wires connecting the circuit board to the Carbon brushes.
This may be as simple as a faulty cable check for power to the circuit board.
Andis AGC2 Hair... | Answered on Feb 11, 2014
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
no diagrams but give us a call and we can talk you through it
http://www.angliaclipperservices.com/index.php?route=information/contact
Drive bearings can only be replaced (safely) by removing the motor and then the armature.
Instructions come in with a new drive assembly, basicly put the black end through under the metal frame first then push it down into place.
You can find instructions on the following link
Fitting Cable
Yep as simple as that just make sure they are a well recignised sharpener otherwise you will waste your money. You can rule out a clipper problem if other blades cut ok. Clipper Blade Sharpening
Hi I know its a late reply but this sounds just like a power cord problem you can buy a new mains lead for the clipper from UK based company Anglia Clipper Services
Ok if you take them appart don't touch the screws you will find it hard to re-align, if your blades haven't been sharpened for 5 years the i think its a very good place to start
Andis AGC2 Hair... | Answered on Sep 21, 2011
Neither the circuit board need jacking up with a washer either side or worst case a new Circuitboard.
Andis AGC2 Hair Trimmer Logo
33 questions posted
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Andis Health & Beauty
Most Popular Question
used clippers
  • Health & Beauty
