20 Most Recent
Lanzar Vibe 235 Car Audio Amplifier Questions & Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to purchase an old school Lanzar Opti Drive. Any of them. The 50 will kill some 12" subs
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Lanzar
Lanzar Vibe 235...
Answered
on Dec 19, 2014
What color is it? If it is Clear or white it is actually a 25 amp fuse. Otherwise, what kind of fuse is it? if it is a regular "little fuse" you should be able to find it anywhere they sell fuses like Walmart. Or you should go to an audio shop and they would have one. Hope you find one.
-Andrew Hawkins
Lanzar Vibe 235...
Answered
on Dec 07, 2008
You would need a Line Output Converter (LOC) to convert the speaker level of the head unit to preamp level.
The amp also has speaker level inputs but the LOC will probably produce better results.
Let me know if you have any other questions.
Lanzar Vibe 235...
Answered
on Aug 27, 2008
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Lanzar Vibe 235...
Answered
on Jan 28, 2008
try redoing the wires you might have wires touching somewhere if that dont stop it try new RCA wires
Lanzar Vibe 235...
Answered
on Jan 09, 2008
Bad connection inside either on a connection or on the PCB itself.
Lanzar Car Audio...
Answered
on Dec 31, 2020
When an amplifier causes trouble or otherwise stops working, it is necessary to eliminate external possibilities such as a short circuited output.
If nothing external is causing the problem, unless you have a good friend who is an electronics engineer, it will be a repair shop task...
Lanzar Car Audio...
Answered
on Apr 27, 2020
