20 Most Recent
BlueStar RNB36 (Gas) Kitchen Range Questions & Answers
Oven won't light
Hi, your in need of a new glow plug igniter unit. approx cost 50 to 60 dollars and can be replaced by yourself if your a little handy. This is a common part to replace in this gas range.
Front middle burner won't light. Just clicks and
You can buy the parts directly from Bluestar. Their service/parts request form is
here. The ignitor is easy to replace, I just recomend that you replace the screw that holds it in place as well. Eventually the screw will rust and become difficult to replace unless you do it every time.
Igniter wont stop firing
I had the same issue. I needed to plug the plug into a properly grounded outlet. The have little testers for like $5 at Home depot. Plug in the tester, if the incorrect lights come on, that's your problem, or run a GROUNDED extension for another outlet and see if it works.
No spark and no power: Bluestar 36
Is there power at the outlet? I know that it is probably very hard to get to behind the heavy Bluestar, but it looks like you may have to pull the stove away from the wall and make sure it is still plugged into a working outlet. All of those stove functions are fairly separate, so to have all of them go out, you probably have a power supply problem. There may even be a break somewhere between the plug and where it splits off into the fan/light/ignitor parts.
