20 Most Recent 2000 Hyundai Accent Questions & Answers
I need a radio wiring
Radio 12v orange/black + radio
Radio Ground black - radio
Radio Ignition blue/black + radio
Radio Illumination green/orange + radio
Factory Amp Turn-on
Power Antenna pink + radio
LF Speaker +/- red - blue radio
RF Speaker +/- white - brown radio
LR Speaker +/- green - orange radio
RR Speaker +/- orange - blue radio
2/10/2022 9:07:15 AM • 2000 Hyundai... • Answered on Feb 10, 2022
3answers
Where is the fuel filter located on a 2004 hyundai
The fuel filter on a 2005 Hyundai Accent depending on where it was manufactured and when, is possibly external and on the outside of the fuel tank directly above the fuel pump and accessible by removing the back seat. Or it is actually inside the fuel tank and requires removing the back seat, the metal panel, the fuel pump itself and then accessing the filter. Your vin. no. can determine which model you have and of course how much work you'll have to do
12/17/2021 9:11:38 PM • 2000 Hyundai... • Answered on Dec 17, 2021
4answers
With the ignition off, the rear tail lights won't turn off
hiya if the rear lights are remaining on ? with no ignition it will be the brake lights staying on this is easily remendied/ checked by trypulling the brake pedal up by hand and see if lights go off ? if so then you will need to adjust the b/light switch which is positioned adjacent to pedal and can be screwed inwards towards the pedal untill the plunger on switch is pushed into the switch which puts lights off ensure pedal is fully up then adjust switch reconnect the wire/plug and press pedal slightly to ensure b/lights operate ok and then go off with pedal released ? on hyundai the brakelights do not req ignition on to operate hence more likely problem is as above good luck
3/31/2021 6:15:52 PM • 2000 Hyundai... • Answered on Mar 31, 2021
2answers
Rear window washer does not spray fluid. When I
I have the same problem with my 2000 chevy blazer as skornec had posted. I kinda already figured the hose or spray nozzle was plugged. But the problem with checking those items is that I don't know where the hose is located to the back wiper. And the only thing that could be I see that could be the spray nozzle doesn't even have holes that washer fluid could spray from. So basically I just would LOVE if someone could please inform this lame brain of where to find the spray nozzle on the rear window and where in the interior of my blazer does the washer hose run.
3/7/2020 3:00:42 AM • 2000 Hyundai... • Answered on Mar 07, 2020
Check coil pack on 2000 Hyundai accen
I think you could use this manual method instead.. My nephew use it to repair my car and it's totally repaired now. Here's the website he bought it from. reliable-store
2/18/2019 9:51:13 AM • 2000 Hyundai... • Answered on Feb 18, 2019
2answers
My 2000 hyundai accent makes a small noise while turning
if it was the cv joints it would do it when you drive it it seems like its the bushings in the a arms
11/4/2018 2:09:20 PM • 2000 Hyundai... • Answered on Nov 04, 2018
Need torque specs for connecting rod and main
Torque in two to three stages.
Connecting rods are 24-26 lb.ft.
Main bearing caps are 41-44 lb.ft.
Hope this helps,Chuck
10/29/2018 10:43:25 AM • 2000 Hyundai... • Answered on Oct 29, 2018
3answers
2000 hyundai accent passenger door willnot
the door 'lock/unlock' actuator is siezed up (corroded).... replace it (or have it replaced).
9/29/2018 8:02:13 AM • 2000 Hyundai... • Answered on Sep 29, 2018
What is the meaning of trouble code U0019 in
Hi.
U0019 - CAN Bus B Error
Thanks!
4/19/2018 1:06:00 PM • 2000 Hyundai... • Answered on Apr 19, 2018
I have a 2000 Hyundai Accent and the air con gets cool but not cold and it struggles to keep up on a hot day. Does anyone have any idea what this might be i have had the gas checked and all is good be
check pressures in the system at 1500 rpm suction side (blue) should be about 35lbs. high side (red)should be no more than 350. radiator fan must run constantly with ac on. if all else checks out, the blend door inside the heater case might not be closing off the heater core allowing heat to sneak by and reduce the cooling effect.
3/3/2018 5:36:37 AM • 2000 Hyundai... • Answered on Mar 03, 2018
I have a 2000 hyundai accent 146,000 miles
there is usually a transmission cooler in the front of the car. transmission fluid flows through rubber or steel lines to the trans cooler and back. those lines are commonly known to rust and leak.
3/3/2018 5:01:52 AM • 2000 Hyundai... • Answered on Mar 03, 2018
2answers
Windshield wipers on 2000 Accent don't work.
Maybe the wiper motor linkage is the problem . Try an run the wiper motor by it's self .
12/15/2017 4:17:52 PM • 2000 Hyundai... • Answered on Dec 15, 2017
2003 hyundai tiburon GT 6cyl. Engine shut down on
My dad's a mechanic and he bought these online stuff that you get instantly, so he would fix it right away. Hope this helps.. Best Manuals
12/8/2017 7:21:09 PM • 2000 Hyundai... • Answered on Dec 08, 2017
2000 Hyundai accent. Trunk open
You should have a switch in the trunk area or on the trunk latch it makes contact to ground to turn on the light in trunk if you disconnect the switch should take care of it temporarily.
11/30/2017 7:08:35 PM • 2000 Hyundai... • Answered on Nov 30, 2017
Hyundai Accent 1.4L GLS 2000 Central Locking not working
FOR Central locking not working on 2000 Hyundai accent?Click the link below :-----
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
11/11/2017 6:26:20 PM • 2000 Hyundai... • Answered on Nov 11, 2017
My 2000 hyundai accent wouldn't start. when i
a ECM is not reset by removing the battery terminal That causes more problems in the CPU program and also looses any radio codes ECM units are reset by the use of a scan tool Take it to an accredited service shop , have the fault codes read to see exactly is causing the problem , then have the ECM reset using the scan tool
11/9/2017 9:44:12 PM • 2000 Hyundai... • Answered on Nov 09, 2017
When I push the gas pedal my car's check engine
That may very well be correct.Asking for acceleration needs a strong spark and these parts will provide that. All that for $242 installed? Great deal.
10/24/2017 11:23:49 PM • 2000 Hyundai... • Answered on Oct 24, 2017
2answers
I have Hyundai Accent GT
Try hooking your seat belt, put it on, before you try to start the car.
8/17/2017 5:56:44 PM • 2000 Hyundai... • Answered on Aug 17, 2017
0answers
2000 Hyundai Accent Logo
1,518 questions posted
Popular Products
2001 Hyundai Accent
2001 Hyundai Accent
1,082 Questions
2002 Hyundai Accent
2002 Hyundai Accent
1,047 Questions
1999 Hyundai Accent
1999 Hyundai Accent
517 Questions
2003 Hyundai Accent
2003 Hyundai Accent
500 Questions
1997 Hyundai Accent
1997 Hyundai Accent
255 Questions
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
View Most Popular
Accent Hyundai
  • Accent Hyundai
Most Popular Question
heater nt come
  • Cars & Trucks
