20 Most Recent Zoom RT-223 - Portable Drum and Bass Rhythm Generator Questions & Answers
In most cases there could be a protector in the input section of the DC and this would prevent cross polarity or excess voltage. However if your voltage had exceeded the threshold set within , it could have damaged the IC's. In this case it will be wise to inspect the PCB and check for the damage and if your lucky, it could be only a burnt thermal resistor. Good Luck.,
Zoom RT-223 -... | Answered on Mar 09, 2016
It is a formatting issue. Look either on the remote control or in the user menu for an option called ASPECT or FORMAT. Adjust these until the optimal setting is achieved.
Zoom Televison &... | Answered on Aug 09, 2009
need codes for my remote
Televison &... | Answered Yesterday
The remote for the DMR-EZ485v can't change the REMOTE CONTROL (RC1) to RC2. Even when following the instructions above.
Some help here. The issue is normally overheating. If it is part of your rental package, contact the supplier for a new one.
https://www.google.com/search?q=converter+box+keeps+rebooting
Do a factory reset!
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
THEN LOOK FOR YOUR REMOTE HARDER WE DID NOT LOSE IT FOR YOU
try taking batreries out of remote and restarting tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Hello there,
You just bought a wrong DVD-player or DVD-disc for your country.Although I believe it is illegal you could try to 'hack' your DVD-player and make it region-free. A list of DVD-players that can be hacked you find here.http://www.videohelp.com/dvdhacks
Good luck and best regards, FriskyRThank you for using FixYa, please rate this solution 4 thumbs if it was usefull. If not, please let me know.
What is brand name and model number of the device you have? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Without a remote control; you can't select any functions. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
You did not post the model number but I can tell you that if lightning damaged it, get a new one. Since I dont know your location or situation, you may be able to make an insurance claim if it applies. Lightning is very high voltage and can damage things that are electronic in ways that you cannot detect or see without special equipment. Even then it can damage entire boards, circuits and most components.
Televison &... | Answered 2 days ago
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Zoom RT-223 - Portable Drum and Bass Rhythm Generator Logo
1 questions posted
Top Zoom Televison & Video Experts
Marvin
Marvin
Are you a Zoom Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zoom Televison & Video
Most Popular Question
think may permanently damaged machine
  • Televison & Video
