20 Most Recent 1997 GMC Jimmy Questions & Answers
1997 GMC Jimmy. My windows will not roll up or down unless the blower motor is running!
I would check wires at doors opening . you have to remove rubber and look for open circuit. Pull on each wire . you will see. Ground problem ??
3/23/2024 12:14:13 AM • 1997 GMC Jimmy • Answered on Mar 23, 2024
How do you put the jimmy in neutral to move it
Im assuming that it's an automatic...Depress the brake pedal, turn the key to the run position, and shift it into"N."
10/16/2023 1:13:48 PM • 1997 GMC Jimmy • Answered on Oct 16, 2023
What are some signs of my relays in my glovebox are bad on my 1997 gmc jimmy
Certain things wont operate. Buy a haynes repair book at parts for testing fuses&relays
4/20/2021 5:57:23 AM • 1997 GMC Jimmy • Answered on Apr 20, 2021
3answers
P0306
Its your No. 6 Injector. I had the same problem on my 97 Jimmy. Replaced the SPYDER injectors and it runs fine now.
6/13/2019 9:21:27 PM • 1997 GMC Jimmy • Answered on Jun 13, 2019
2answers
Rocker arm torque specs on a 97 gmc jimmy 4.3
  1. For the 4.3L engines which are equipped with screw-in type rocker arm studs with positive stop shoulders, tighten the rocker arm adjusting nuts against the stop shoulders to 20 ft. lbs. (27 Nm) on 1994-96 models and 18 ft. lbs. (25 Nm) on 1997-99 models. No further adjustment is necessary, or possible.
  2. For most 4.3L engines which are not equipped with screw-in type rocker arm studs and positive stop shoulders, properly adjust the valve lash. For details on valve lash adjustment, please refer to the procedure in Routine Maintenance . (see below)
4.3L Engine
The 4.3L engines may be equipped with either of 2 rocker arm retaining systems. If your engine utilizes screw-in type rocker arm studs with positive stop shoulders, no valve lash adjustment is necessary or possible. If however, you engine utilizes the pressed-in rocker arm studs, use the following procedure to tighten the rocker arm nuts and properly center the pushrod on the hydraulic lifter:
  1. To prepare the engine for valve adjustment, rotate the crankshaft until the mark on the damper pulley aligns with the 0? mark on the timing plate and the No. 1 cylinder is on the compression stroke. You will know when the No. 1 piston is on it's compression stroke because both the intake and exhaust valves will remain closed as the crankshaft damper mark approaches the timing scale.
Another method to tell when the piston is coming up on the compression stroke is by removing the spark plug and placing your thumb over the hole, you will feel the air being forced out of the spark plug hole. Stop turning the crankshaft when the TDC timing mark on the crankshaft pulley is directly aligned with the timing mark pointer or the zero mark on the scale.
The valve arrangement is as follows:
E-I-I-E-I-E (right bank-front-to-rear) E-I-E-I-I-E (left bank-front-to-rear)
  1. With the engine on the compression stroke, adjust the exhaust valves of cylinders No. 1, 5 & 6 and the intake valves of cylinders No. 1, 2 & 3 by performing the following procedures:
    1. Back out the adjusting nut until lash can be felt at the pushrod.
    2. While rotating the pushrod, turn the adjusting nut inward until all of the lash is removed.
    3. When the play has disappeared, turn the adjusting nut inward 1 3 / 4 additional turns.
  2. Rotate the crankshaft one complete revolution and align the mark on the damper pulley with the 0? mark on the timing plate; the engine is now positioned on the No. 4 firing position. This time the No. 4 cylinder valves remain closed as the timing mark approaches the scale. Adjust the exhaust valves of cylinders No. 2, 3 & 4 and the intake valves of cylinders No. 4, 5 & 6, by performing the following procedures:
    3. When the play has disappeared, turn the adjusting nut inward 1 3 / 4 additional turn.
5/31/2019 2:49:47 AM • 1997 GMC Jimmy • Answered on May 31, 2019
Where is the place for the flashers 1997 gmc jimmy truck.
Flasher module should be located behind the glove box on connector C203 bolted to the firewall. You may be able to get at it by opening the glove box, and then releasing the stop tab at the top left of the opening to swing the box out of the opening on its hinges.
5/16/2019 11:45:02 PM • 1997 GMC Jimmy • Answered on May 16, 2019
Head bolt torque specs on a 97 gmc jimmy 4.3
First, tighten the bolts to 25 ft. lbs. (34 Nm).
Next, tighten the bolts to 45 ft. lbs. (61 Nm).
Finally, tighten the bolts to 65 ft. lbs. (90 Nm).
3/25/2019 10:45:05 PM • 1997 GMC Jimmy • Answered on Mar 25, 2019
My 1997 jimmy won't start but fires, what could be wrong?
Did you change the fuel filter? did you put back right?
5/14/2018 2:04:46 AM • 1997 GMC Jimmy • Answered on May 14, 2018
The driver side mirror was broken off of my 1997
Chime needs only a ground to work So if that can help try to move the harness and look if chime work normally. If it does then one wire touching the ground on and off (wire touching metal) Hope it helps.
4/20/2018 3:39:18 AM • 1997 GMC Jimmy • Answered on Apr 20, 2018
How do you bleed brakes on 1997 GMC jimmy
1997 gmc jimmy brake bleeding -khpbmhaocwhdo3b0pqdplrqt-5-2.jpg Brake bleeding Procedure 1. First, you have to depress pin location (see Image) Keep this pin block so it will not pop out during the bleeding otherwise air will stay trap inside the system. 2. Start bleeding the Brake cylinder that is the farthest from the Brake master cylinder. Do the 4 wheels in the same matter. Hope it helps.
4/20/2018 3:24:00 AM • 1997 GMC Jimmy • Answered on Apr 20, 2018
2answers
Where are the spark plugs in a 1997 gmc jimmy?
Plugs are mounted in the cylinder head(s) .Upper most part of the engine. Follow spark plug wire to their location and they are always found on the exhaust side of that head.
3/1/2018 5:42:30 AM • 1997 GMC Jimmy • Answered on Mar 01, 2018
2answers
Climate control stuck in defrost/floor vents
The problem is probably a faulty diverter door actuator or vacuum problem at the HVAC plenum under the dash. This is a common problem - see YouTube for help diagnosing this: https://www.youtube.com/watch?v=Nlt9A1sp-4U
1/25/2018 5:06:03 PM • 1997 GMC Jimmy • Answered on Jan 25, 2018
2answers
1997 GMC JiMMY when in 4x4 leaks transmission fluid when not in 4x4 it does not
where is the fluid leaking from? The transmission or the transfer case? Pretty important to know where it's coming from before asking for help
1/15/2018 7:57:29 PM • 1997 GMC Jimmy • Answered on Jan 15, 2018
I am trying to troubleshoot a GMC 3500 wiper motor
The only C3500 info I find pertains to pickups and Vans. You need to be very clear about yr, make, model, engine size, 2 or 4 WD. The more info, the better. This is what I see for a 97 Jimmy 4WD. 97 jimmy wiper inoperative-3rfuzzdlkw1qmhbqnoq1cwkt-5-0.jpg
12/31/2017 11:46:01 PM • 1997 GMC Jimmy • Answered on Dec 31, 2017
So much going on??
just get the service and repair manual from the given link and solve all the problem http://toolsnyou.com/
12/7/2017 2:12:20 PM • 1997 GMC Jimmy • Answered on Dec 07, 2017
2answers
97 GMC Jimmy ABS Light on
Have you checked the relays?
11/19/2017 12:35:49 AM • 1997 GMC Jimmy • Answered on Nov 19, 2017
My 97 GMC Jimmy Fan problems.
It sounds like a fan blade is bent and is making contact somewhere , these are usually aluminium and easily pushed back into shape , but if the fan has worn out its bearings it will need to be replaced unless there is some sort of material that has wrapped itself around the fan causing it to jam up .
11/10/2017 9:39:53 PM • 1997 GMC Jimmy • Answered on Nov 10, 2017
I have a 1997 GMC jimmy that won't start with out
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem. Best Manuals
10/24/2017 6:38:32 AM • 1997 GMC Jimmy • Answered on Oct 24, 2017
1,539 questions posted
Popular Products
2000 GMC Jimmy
2000 GMC Jimmy
1,363 Questions
1998 GMC Jimmy
1998 GMC Jimmy
1,127 Questions
1999 GMC Jimmy
1999 GMC Jimmy
1,104 Questions
2001 GMC Jimmy
2001 GMC Jimmy
838 Questions
1996 GMC Jimmy
1996 GMC Jimmy
768 Questions
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
View Most Popular
Jimmy GMC
  • Jimmy GMC
Most Popular Question
1997 gmc jimmy 4 3 liter v6 4 wheel
  • Cars & Trucks
