20 Most Recent Shopnbc Zeki 7" Multi-TouchTablet Questions & Answers
no, absolutely not (only with an emulator, see 2nd link)
as Zeki-tablets use Android OS
- however many apps exist in iOS, Android or other versions
you need to check that with the built in Amazon App store
Ask Mama Reviews
iOS Emulator for Android APK Download Run iPhone Apps on Android Phone download-apple-apps-zeki-tablet-oawkhf2sylgpmq5puvpglfxy-3-0.jpg
Shopnbc Zeki 7"... | Answered on Jan 08, 2020
Could be a Boot Loop. This happens when you have (or attempted to) modify the device's firmware. A factory reset would be the best solution to your problem.
The following web post might be of help;
http://www.gadgetreview.com/2013/05/how-to-factory-reset-your-android-device.html
Good luck
Shopnbc Zeki 7"... | Answered on Dec 27, 2019
Let it run the battery down then recharge and start but it sounds like the boot block and os is hosed in which case its a goner.
It can be volume up or volume down after pressing the power button. Which one did you try - try both. Did you try pressing the reset hole with a pin?
Shopnbc Zeki 7"... | Answered on Dec 14, 2019
It is very possible that the earphone jack is defective and causing the problem. I had a tablet that would not make any sounds through the speakers after I plugged into the earphone jack and then removed the plug. I could hear only through the earphones after that. The problem was caused by a fault in the earphone jack. I had to send the tablet back to the manufacturer where they replaced the faulty jack. But before you send the tablet back to the manufacturer make sure that the tablet isn't muted by going to "settings" then go to "sound" and see if it is turned down or muted.
Shopnbc Zeki 7"... | Answered on Nov 30, 2019
I believe you will have to erase your device and start over.
Shopnbc Zeki 7"... | Answered on Oct 04, 2015
Hi, if the OS is so messed up that it cannot restore you can always format the memory and reinstall it but this is a job that takes a fair amount of time to perform. Check with the manufacturer's wbsite for support on this issue.
Shopnbc Zeki 7"... | Answered on Jun 08, 2015
not chn .help
Shopnbc Zeki 7"... | Answered on May 30, 2015
While is my tablet saying I don't have storage space so now I can't screen shot
Shopnbc Zeki 7"... | Answered on May 10, 2015
mirror??? do you mean steam
Shopnbc Zeki 7"... | Answered on Mar 04, 2015
Yes you can... take a look on amazon for replacement. Here: Amazon com zeki tablet screen. I hope this was helpful. Cheers
Shopnbc Zeki 7"... | Answered on Jan 12, 2015
You can try pulling the battery then reinstall it and restart the unit. If that doesn't clear the problem go to settings, and then applications and look for UI and clear the cache and data. If that fails you can try to do a factory reset.
Shopnbc Zeki 7"... | Answered on Dec 06, 2014
It is possible that the digitizer connection has become dislodged or gone bad. Go to this site and watch the video on how to fix the digitizer.If the tablet is still under warranty you may want to contact the manufacturer before attempting to fix it yourself. https://www.youtube.com/watch?v=YOFqSstNNg4
Shopnbc Zeki 7"... | Answered on Dec 05, 2014
Shopnbc Zeki 7" Multi-TouchTablet Logo
189 questions posted
Top Shopnbc Tablets & eReaders Experts
The Scrivener
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Shopnbc Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Shopnbc Tablets & eReaders
Most Popular Question
touchscreen our zeki tablet cracked
  • Tablets & eReaders
