20 Most Recent
Legacy Audio LA770 Car Audio Amplifier Questions & Answers
Can i fix the transistors on my car amp
stop turning it on, until you change the transistors. you will burn the entire system.
change all the transistor, not only the smoking ones.
check all other components.
I have the subs hooked up to the amp and the
LETS SEE IF YOU HAVE A PROBLEM WITH THE AMPLIFIER ITSELF OR IF SOMETHING IN THE INSTALL
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION OR FAILS TO POWER UP AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. SOMETIMES THE RADIO CAN HAVE A DEFECTIVE SAGGING BELOW 11 VOLTS REMOTE OUTPUT WHICH WILL CAUSE THE AMPLIFIER TO NOT POWER UP. IF YOU DISCONNECT THE RADIOS REMOTE LEAD AT THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER FROM THE POSITIVE POWER TERMINAL AND THE REMOTE TERMINAL OF THE AMPLIFIER, THIS WILL NORMALLY FORCE THE AMPLIFIER ON. AT THIS POINT,YOU HAVE TOTALLY BENCHED THE AMPLIFIER AS IT WILL NOT HAVE ANYTHING TO DO WITH THE ACTUAL INSTALLATION AND IF STILL FAULTY IT SIMPLY WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Bridgeing
u use the first live out put and the last out put wich should b a negative whick will make the amp run all its power into the sub
La1498 amp
If the amp is bridgeable then u should see lettering where the speaker outputs or the channels are and you will a symbol saying bridged and then u can see a + and - symbol with lines going to the other channels. In other words they call it bridged because you are jumping from one speaker output to the other, usually bridging an amp consists of Left - to Right + or vice versa.
Legacy amp 1200 watts
i have had the exact same problem with the exact same lagacy amp that you have posted, put your ground in a different spot or try double grounds in two different spots this should solve your problem here. good luck
Legacy 1200 watts
First thing to look for would be pinched speaker wires,or a bad ground, or a loose b+ wire. The next would be to have the amp bench tested and the tech should bang and tap on the unit to see if there are bad or cold solder connections inside on the printed circuit board assy.
When I select the source
Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
2.) Try checking the connection from your car battery to the audio device...
By the way how old is the player ..
Thanks !!
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
