20 Most Recent Legacy Audio American Legacy II LA690 Car Audio Amplifier Questions & Answers
You need to look at your wiring of the speakers and the Ohm rating on your speakers.
Below are the specs of the amp. You have the Tri-Way amp and the switch that controls
which way it configures it's output is critical. If you are powering just 2 speakers you set the
the Tri-Way to bridge only. Problem is, I cant find a manual. Legacy's site ( Manual Coming Soon.I say call them and ask for a manual to be emailed to you or mailed.
Legacy Car Audio Inc.
1600 63rd Street
Brooklyn N.Y. 11204
Phone (718) 535-1800
Toll Free 1-800-444-5671
You can also contact us by email For Support [email protected]
  • American Legacy II Series
  • 1000W High Performance 4 Channel Bridgeable Amplifier
  • Tri-Way Output Configuration:
    • 250W x 4 Channel Power Output
    • 500W x 2 Bridged Power Output
    • 250W x 2 Channel (Front) + 500W x 1 Channel (Rear)
  • 2 Ohm Stereo Stable
  • Legacy Audio... | Answered on Mar 19, 2011
    Check this out: http://www.techlore.com/article/14696/
    Legacy Audio... | Answered on Feb 12, 2010
    in shop visit weeklyvisiters.blogspot.com
    Legacy Audio... | Answered on Sep 10, 2009
    it's shutting off for a reason. What speakers are you trying to run? Do you know what impedance they are wired for? Where is the gain set? When bridged that amp is only stable at 4 ohms mono and will/should shut down at impedances lower than that.
    Legacy Audio... | Answered on Sep 26, 2008
    Have you checked the fuses on the amp?
    Have you confirmed that you have both B+ and remote voltage at the amp?'
    When measuring the voltage, place the black meter probe on the ground terminal of the amp.
    Legacy Audio... | Answered on Sep 18, 2008
    Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
    1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
    2.) Try checking the connection from your car battery to the audio device...
    By the way how old is the player ..
    Thanks !!
    Legacy Audio Car... | Answered on Mar 28, 2009
    You need to calibrate put a DVD in on the remote press stop,zoom, up, down screen should pop up touch the cross touch the cross at each corner u will see ok turn off and back on and try it
    Car Audio &... | Answered 18 hours ago
    That image just shows that you have chosen Auxiliary Input, can't see the red dots. Looks like you just need to reconfigure it.
    Car Audio &... | Answered Yesterday
    Tip & How-To about Watches
    Changing Watch Batteries
    Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
    Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
    Posted by Andrew... on Dec 31, 2018
    Car Audio &... | Answered 3 days ago
    There are lots of suggestions, specs and plans for loudspeaker enclosures available online with accompanying formulas for calculating sizes of boxes, ports, etc., but successful results tend to be achieved by experience as much as following plans and tuned port reflex enclosures are akin to the black arts - hifi purists would change the port size after a "bedding in" time for the enclosure and drive unit.
    Your subs are rated at 300 rms so clearly you are overloading them at 350/400 and you should be aiming to max them at around 250 in a reflex cabinet. If you really must drive them so hard you really need to consider an infinite baffle as an alternative enclosure.
    Car Audio &... | Answered on Jan 18, 2020
    Legacy Audio American Legacy II LA690 Car Audio Amplifier Logo
    11 questions posted
    Top Legacy Audio Car Audio & Video Experts
    Dalynn Turner
    Mark Skinner
    Professor_V
    Professor_V
    Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
    View Most Popular
    • Legacy Audio Car Audio & Video
    Most Popular Question
    amp shutting off going into protection
    • Car Audio & Video
