20 Most Recent
Omega 8005 Juicer Questions & Answers
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed.
If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there.
If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Omega Juicer VSJ843 Wont Power On
It could be the fuse is bad and the cord is also bad too. The fuse inside of the juicer and the power cord will both need to be replaced.If the motor has quit working then you will have to buy another juicer.
My omega 8003 juicer will not power on
1. test for power at female end of cord? (eliminates, breaker, socket, cord, plugs, all wiring to appliance. I think this appliance is hard wired at the connection, so you may need a non-contact tester.
