20 Most Recent 2003 Mitsubishi Galant Questions & Answers
2003 Mitsubishi Galant station wagon. How to bypass the immobilizer on it?
Question edited for clarity. Question moved to model category. Quite simply you can't bypass it. There are two computers and a security module, plus sensors to stop exactly what you are trying to do. You have to fix it, not find away around it. Your car came with three keys from new. When you are down to one key, that is the time to get another made and programmed (cloned) from the other good key. All cars need 2 keys, my 2005 still has the 3.
Mitsubishi Galant Questions - Immobilizing theft device
CarGurus https://www.cargurus.com > Cars > Discussion-t8136_... Immobilizing theft device - Is there any way to by pass the anti theft device on a 2000 Galant es. 3 answers ยท 0 votes: Nope // one of the most asked questions. ============== You need and auto electrician or an auto locksmith to program the chip in the key and the chip in the ignition transponder to be paired. Then the ECM and the BCM will let you start the car. https://www.google.com/search?q=mobile+auto+electrician+near+me https://www.google.com/search?q=mobile+auto+locksmith+near+me ..
9/15/2023 7:32:28 PM • 2003 Mitsubishi... • Answered on Sep 15, 2023
2.4l. Why does it have a hard/long initial startup?
Check the coolant temperature sending unit it sounds like it's starting on a lean mixture or warm engine even when it's cold.
3/17/2022 6:24:43 AM • 2003 Mitsubishi... • Answered on Mar 17, 2022
3answers
Mitsubishi forum
Take a look at the control arm bushings. Their being worn will cause the knock when going over bumps.
11/24/2019 9:04:45 PM • 2003 Mitsubishi... • Answered on Nov 24, 2019
3answers
Have to turn key several times for car to start
when you turn the first or second time what happens and for how long does it crank?
11/15/2019 5:14:17 PM • 2003 Mitsubishi... • Answered on Nov 15, 2019
Where is the crankshaft position sensor located on a 2003 Mitsubishi Galant? I would appreciate all steps,pictures,etc.
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer. .. rest is up to u.. U can also get free manuals
4/1/2019 9:41:56 AM • 2003 Mitsubishi... • Answered on Apr 01, 2019
Diagram of exterior fuse box 2003 Mitsubishi Galant
Try "you tube" for your diagram.
3/30/2019 2:50:11 PM • 2003 Mitsubishi... • Answered on Mar 30, 2019
Diagram exterior fuse box diagram 2003 Mitsubishi gallant
Fuse and relay identification should be printed on the fuse box cover.........
3/27/2019 6:11:45 PM • 2003 Mitsubishi... • Answered on Mar 27, 2019
The location of oil pump in a 2003 mitsubishi galant
Internal...
5/6/2018 5:22:50 PM • 2003 Mitsubishi... • Answered on May 06, 2018
0answers
Where is the crankshaft position sensor located on a 2003 Mitsubishi Galant 4 cylinder
Hello, crank position sensor located at the 2 o`clock position hidden behind timing cover and crank shaft pulley. If you look closely in well lit area or use a flashlight you can follow the (CCPS) harness down the right hand side of timing cover to where it goes into lower timing cover on lower right hand side of crank shaft pulley. It can be replaced with out removing timing belt. Please note if the 60,000 miles heavy service interval for timing belt is needed and water pump condition should be observed when repairing the crank position sensor.
2/21/2018 8:49:58 AM • 2003 Mitsubishi... • Answered on Feb 21, 2018
I have a 2003 Mitsubishi gallant 2.4. it will not
Check, there is a small wire (3rd wire), going to the starter motor, whether it is connected to the motor
Check the fuses and relays
2/3/2018 6:06:31 AM • 2003 Mitsubishi... • Answered on Feb 03, 2018
My 2003 galant is leaking antifreeze onto my transmission resivior, trouble shoot?
This could be a cracked tank for your radiator filler. Try placing a clean paper towel under the antifreeze tank and fill it with coolant. If there is a crack in the tank you will see it or the results of it. Replace the antifreeze tank - these things get cracked when people put water in the tank instead of mixed water and antifreeze. You get a hard freeze and bingo - your coolant tank breaks - usually on a seam and underneath it where you can't easily see it.
11/20/2017 10:22:05 AM • 2003 Mitsubishi... • Answered on Nov 20, 2017
My car is overheating when in traffic and losing
Check all hoses and also see if your water pump is leaking. There has to be something that is leaking possibly in the area of your floor boards. I suspect a hose that has a pin hole in it and only leaks under pressure.
11/13/2017 2:00:58 AM • 2003 Mitsubishi... • Answered on Nov 13, 2017
Driver side door locking with remote but will not unlock.
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
10/11/2017 1:53:34 AM • 2003 Mitsubishi... • Answered on Oct 11, 2017
Changed the fuel pump in my 2003 mitshubishi galant and it is still not getting fuel. Could it be that my computer is not letting it? How do I figure out how to make my computer to let it get fuel?
Try this, disconnect your battery for about 4 hours and put together the terminals that go from your car to the battery, do not touch the battery! ONLY have the terminals from your car, the ones going to your motor touch each other. I repeat do not touch the battery, you don't even need the battery to be in your car while you do this. and that should reset your computer. to me it sounds like immobilizer has gone into a security mode. try it, it wont hurt. you might need your stereo code because it will be on anti theft after disconnecting the battery, most of the time you will find the code somewhere in the glove box. pls vote.
10/9/2017 8:26:06 AM • 2003 Mitsubishi... • Answered on Oct 09, 2017
Button difficult to depress to shift out of park
Is it a floor shifter? If so i wouldnt have used wd40.. It collects dust and contaminants. If anything on moving plastic to metal parts like that or plastic to plastic a silicone lubricant is more preferable. Its likely time for a new shifter Knob is where i would start. There should be either an oversized staple looking peice that retains the knob on the shifter itself, or it could possibly screw off as well.
10/3/2017 9:07:23 PM • 2003 Mitsubishi... • Answered on Oct 03, 2017
2answers
I just bought an '03
As long as you get a rebuilt from a credited place you'll be okay
9/30/2017 2:21:49 AM • 2003 Mitsubishi... • Answered on Sep 30, 2017
2003 Mitsubishi Galant Logo
1,152 questions posted
Popular Products
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
View Most Popular
Galant Mitsubishi
  • Galant Mitsubishi
Most Popular Question
2003 mitsubishi galant 2 4 engie runs
  • Cars & Trucks
