20 Most Recent 2005 Dodge Caravan Questions & Answers
Dodge caravan screen tv wont work
How to turn on the TV screen on in a dodge caravan 2005
3/11/2023 7:02:24 PM • 2005 Dodge... • Answered on Mar 11, 2023
2005 Dodge Caravan firewall
we can't see you hands touch what./ learn to post photos of things you do not undertand to the blind here. no that is HVAC (my best ESP lame guess is) HVAC is AC cooling lines , most are shinny aluminum. and all have high side / low side R134 port fittings if they leak then the fitting valve is a wreck. and needs full AC vacuum pump down and refill. after new valve bad is replaced. first. at (evacuate and store step done) using cheap gauges does that, if the gauge fitting is dirty . or your R134a fill port is dirty and you connect them. you wreck the valve. with junk. (or both dirty, wow) we blow them out first with shop air to avoid that bad act;. if lucky (not now too late) tickle the valve until it shuts off.
10/19/2022 2:56:40 PM • 2005 Dodge... • Answered on Oct 19, 2022
2answers
2005 Dodge Caravan horn not working
might be the horn itself,power it with a jumper wire to power to see if it works
2/21/2021 9:00:49 PM • 2005 Dodge... • Answered on Feb 21, 2021
3answers
05 dodge caravan fuel pump is good but will not
When you say that the fuel pump is good, do you mean that you did a pressure test on it and it was in specs or do you mean that it energizes? If it does engergize then I would do a pressure test on it to make sure that it has the strength to pump fuel from the fuel tank up to the engine.
4/7/2020 6:05:21 AM • 2005 Dodge... • Answered on Apr 07, 2020
Where is the crankshaft sensor located on a 2005 2.4L Dodge caravan
on the trans bell housing near the firewall side. it picks up signal from flywheel
9/15/2019 12:40:49 PM • 2005 Dodge... • Answered on Sep 15, 2019
Rear tail lite for 2005 dodge caravan
You can google your question and find answer. About 8,970,000 results (0.73 seconds)
5/16/2019 2:41:55 PM • 2005 Dodge... • Answered on May 16, 2019
2answers
2005 dodge caravan oil pan gasket damage, front inner tie rod loose, sway bar links loose boot leak how much will it cost to get this repaired
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
3/16/2019 9:25:11 AM • 2005 Dodge... • Answered on Mar 16, 2019
2005 dodge Caravan wont reverse
Need to know will it go into and drive in all the other gears like it should?
2/27/2019 1:17:34 PM • 2005 Dodge... • Answered on Feb 27, 2019
8answers
2005 Dodge caravan dashboard indicator lights and dials went haywire
2005 Caravan I had the same problem with my van gauges bounceing, headlights not comeing on when the switch was turned on.I took a day and downloaded a wireing diagram from dodge and studyed it.GROUND PROBLEM dodge have several ground conections to the body then there is one MAIN BODY GROUND.This is most likely your problem it is easy for any back yard mechanic to fix.This main body ground is located under your battery box.You will have to remove the battery and then the battery box becarful of the battery sensor that is mounted in the bottom of the box.Also there is a hose that you will have to disconnect but dont try to remove it from the box remove it from above the box.After you get the battery and box out you will see a threaded stud with a black wire conected to it this will be rusted because of no antioxide grease applyed.You will have to remove the nut and wire connector clean both and the stud with wire brush or sandpaper.Put antioxide grease or if nothing else some vaseline to keep it from coroading again.put back together and see if this dosent fix your problem.It has been six weeks for me now.good luck.dont forget that neg battery terminal is the first one to disconect and the last to reconect.
2/11/2019 8:06:10 PM • 2005 Dodge... • Answered on Feb 11, 2019
2answers
Heater blowing out cold air
Several things.If the heater hoses are hot, the problem could be a blend door under the dash. The blend doors direct air thru the heater core and out the vents.
12/18/2018 10:41:34 PM • 2005 Dodge... • Answered on Dec 18, 2018
2005 dodge caravan 2.4 , location of crankshaft
2005 Dodge Caravan SE 2.4L Engine. Crank Shaft Sensor is located on the front of the engine (side toward the radiator) and right below the starter.
Raise the vehicle on stands or ramps. From under the vechcle, unclip the wire plug. Loosen and remove the 8mm bolt. Pull out old sensor.
This CAN be done WITHOUT removing the starter. Easiest way is to use a deep 8mm x 1/4” drive socket and good lighting. I had to use vise grips to grip and pul out the old sensor. It is okay to twist and pull.
NOTE: I have seen many posts placing this sensor in all kinds of places. For this vehicle, this is where it is located. If you have a different engine or year, it could be located someplace else.
5/25/2018 10:46:35 PM • 2005 Dodge... • Answered on May 25, 2018
2answers
My headlights wont work i changed the bulbs still will not work. 2005 dodge caravan
This is some info on your headlamps. Hope you can read it, the text is a little small. Now, autolamps info, may be a little different. headlamp system-pmbrfu23wyzjtvkvaqdpnyxc-2-0.jpg
5/20/2018 9:04:05 PM • 2005 Dodge... • Answered on May 20, 2018
2005 dodge caravan both rear door does not unlock...
Unplug connector to lock actuator and use meter to check for power and ground toggle as you use the door lock button. If you see power and ground toggle, then the problem is the actuator. Replace it/them. If no power/ground toggle, you've got a wiring problem in the traveling cable at the bottom of the door. VERY VERY common.
4/27/2018 4:10:58 PM • 2005 Dodge... • Answered on Apr 27, 2018
2005 caravan will not start
either bad battery connections or a bad (dead) battery.
2/12/2018 4:15:01 PM • 2005 Dodge... • Answered on Feb 12, 2018
2answers
My remote keyless entry does
Hello Terimau, The first thing a dealer would do... attempt to PROGRAM (reacquaint you RKE fob with your Caravan). Perhaps you overlooked to PROGRAMMING of the unit... (FOB). It must be coded into your VEHICLE memory... ELSE Chrysler Corporation Security would be an eBay sale away from total defeat. RKE (remote keyless entry) is covered in detail on pages 10,14,22,23,28,29,42,46-49,94 & 151 in your owners manual as seen below Dodge Grand Caravan Owner Manual Remote Starting System If Equipped Hope this gets you started... Carnac the Magnificent
1/12/2018 2:10:33 PM • 2005 Dodge... • Answered on Jan 12, 2018
2005 Dodge Caravan Logo
2,105 questions posted
Popular Products
2000 Dodge Caravan
2000 Dodge Caravan
2,271 Questions
1996 Dodge Caravan
1996 Dodge Caravan
1,337 Questions
1998 Dodge Caravan
1998 Dodge Caravan
1,299 Questions
1999 Dodge Caravan
1999 Dodge Caravan
1,150 Questions
1997 Dodge Caravan
1997 Dodge Caravan
1,016 Questions
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
View Most Popular
Caravan Dodge
  • Caravan Dodge
Most Popular Question
2005 dodge caravan 2 4 change fuel pump
  • Cars & Trucks
