20 Most Recent Oster 12-Bottle Wine Cellar - Black Questions & Answers
I had the same problem as other bloggers--temp would not decrease and fan did not run. . . as suggested by others, I replaced the 5A heat-shrink wrapped fuse in upper left corner of circuit board (fuse is covered in black heat shrink wrap and is in a U-shape). I unsoldered the two ends of the fuse on the circuit board (be sure you locate the correct two holes) and then replaced it with two parts from Radio Shack--a 5x20mm Inline Fuse Holder rated at 250V AC, 5A (part # 270-1238) and used a 6.3A slow-blow 250V fuse (part # 270-1066). Now the wine Refir works great!
To replace the part take all the screws off the sheet metal covering on the back of the refrigerator. Remove the circuit board from the plastic holder. I left all the wires plugged in and just unsoldered the fuse with the circuit board still connected--but to solder you will need an extra pair of hands to hold the board while you solder.
If you don't have it, get some silver solder while at Radio Shack and a thin, needle-point soldering iron tip. Radio shack has 30W soldering irons for less than $10. You really don't need soldering experience--just a steady hand. Even if you have none of these parts your total outlay at RadioShack is less than $25 for everything.
Oster 12-Bottle... | Answered on Apr 17, 2017
And what is your question or questions
Oster 12-Bottle... | Answered on Feb 26, 2017
the up and down arrow pretty much sets the temperature
it doesn't appear so because it flips back to the current fridge temperature.
Oster 12-Bottle... | Answered on Jan 16, 2017
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Oster 12-Bottle... | Answered on Jun 11, 2015
Oster 12-Bottle Wine Cellar - Black Logo
76 questions posted
Top Oster Furniture Experts
ThaMp3Doctor
ThaMp3Doctor
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Are you an Oster Furniture Expert? Answer questions, earn points and help others
View Most Popular
Oster Furniture
  • Oster Furniture
Most Popular Question
fans not working
  • Furniture
