20 Most Recent
Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit Questions & Answers
I've had a Spotstar #5 Radio for Home Use since
it could be the signal has been down graded. new laws on signal and strengths have been coming in over the fear of wave format. the best way to gain a weak signal is a booster of some kind to bring in the weak signals, hope this helps.
I purchased a 2008 g35
Turn the radio on an locate the Radio ID
For XM Radios
Your Radio ID can be displayed by tuning your radio to channel 0. (That's one channel down from the XM Preview.) Make sure to check your ID code carefully. Please note that the following letters are not used: I,O, S, and F.
Call the activation hotline to activate your service
1-866-635-8634
I have the sportster rewind 2 i did not pay my
If you don't pay your bill, you'll need to buy a new radio, since they'll lock it out of the network. You *might* be able to have it activated online, so try that out before giving up. If that won't work, then just sell it for parts on eBay, if it's a functional (but banned) radio, you'll probably get $20-$40. Make sure you mention it's banned.
THIS UNIT AFTER 3 YEARS WILL NOT RECGONISE AN
Hi Glenn,
Understandably frustrating, but it sounds like an easy fix.
First, go through the settings on your radio to be certain that nothing was set incorrectly.
Second, make sure your antenna wire is not malfunctioned or tampered with. Broken pins can render an antenna useless. These satellite radio antennae are fairly cheap to purchase on their own, so you could try purchasing a new one and see if it works.
If that's fine, open the receiver. Generally these radio's use small torx or philips screws. Once opened, check the area where the antenna is plugged in - is the lead/wire broken? Is the solder coming off? All of this can be fixed easily if spotted. You can even solder the antenna permanently on if you like.
I have 12 volt power coming to the cradle, and
Check the center pin on your unit, and also check if your dock connector has any damage. If it is not damaged, then push on the unit while it is docked. If it turns on after 30 seconds then you have a cold solder joint on your power connector. Just remove the back cover and solder the barrel connector's pins back down. There is one on the left and one on the right, both must be soldered in order to receive power.
Why can't i get oprah
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
In my settings there is no fm transmitter
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
