20 Most Recent Philips Ambilight 2 52 in. Flat-Panel LCD HDTV Questions & Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Philips... • Answered on Jun 08, 2017
Have you tried turning it on in the menu options. Navagate thru the menu there is a setting for on or off on the Ambilights.
Philips... • Answered on Jun 08, 2013
7_16_2012_7_57_45_pm.jpgmodel 52PFL3704D/F7 flat tv Philips
Philips... • Answered on Jul 16, 2012
this shows that the standby power is present,check and test the horizontal output transistor and the filter capacitor for their functionality and replace then give it a try but by first connecting a 100w light bulb in series where the power input fuse is supporsed to be.if the tv can turn on then you can now put back the fuse and test again
Philips... • Answered on Sep 16, 2011
Just replaced lamp and now blue power light keeps flashing
Philips... • Answered on Jun 29, 2011
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Philips... • Answered on Mar 12, 2011
Unfortunately the video you are giving the tv must be one of the last systems the uProcessor in the tv checks. It takes about 15 seconds to detect signal/no signal for each system. Good old automated technology!
Philips... • Answered on Dec 31, 2010
Unplug the power for 10 mins. Try turning ON again. If the probelm is still there then, you need a new main power supply assembly
Philips... • Answered on Oct 11, 2010
Let me know model number and brand of your tv to provide you possible cause of problem and its solution.
Please unplug tv from AC wall socket for minute, replug back in and turn it On, some times it solves problem.
How old is this tv?
Thanks.
Philips... • Answered on Mar 04, 2010
my 32" panasonic lcd t.v will not turn on but the red light keeps blinking in front?
Philips... • Answered on Oct 12, 2009
The first mistake was the Philips TV. They are the worst tv. They are constantally needed to be updated. If you have warranty, I would recommend you taking it back or calling philips customer service and getting your tv repaired or replaced.
Philips... • Answered on Apr 07, 2009
Try 606 or 616 one of those should work.
Philips... • Answered on Mar 06, 2021
It could be because the TV's screen is starting to go bad and that your TV's screen and TV are starting to die on you.
Philips... • Answered on Feb 14, 2021
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Philips... • Answered on Feb 11, 2021
Philips Ambilight 2 52 in. Flat-Panel LCD HDTV Logo
Popular Tags
28 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
few months back
  • Televison & Video
