20 Most Recent
Logitech MX Revolution Wireless Laser Mouse Questions & Answers
Mouse locked up. It was a wireless mouse. Tried
In Control Panel there is option to use your keyboard numeric keypad to move your mouse cursor.
Also you can use tab key from keyboard to select options and then press space or enter to select
Thanks
Need to replace the battery in a Logitech MX
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed. NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery:
MX Revolution L-LY11 BatteryHere is a link to a site that shows you an example of the L-LL11 battery:
L-LL11 Battery for Logitech MX Revolution MouseAs you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
How do I add format to my logitech 650I downloaded from my old logitech to my new logitech and it doesn't have the format button on it
It sounds like you are trying to use the same formatting settings on your new Logitech keyboard that you had on your old Logitech keyboard, but the formatting button is not present on the new keyboard.
To add the formatting button to your new Logitech keyboard, you will need to do the following:
- Open the Logitech Options software. This software allows you to customize the settings and functionality of your Logitech keyboard.
- Select the "Buttons" tab. This will allow you to customize the buttons on your keyboard.
- Find the formatting button that you want to add. Depending on the model of your keyboard, you may have the option to add a variety of formatting buttons, such as bold, italic, and underline.
- Assign a function to the button. To add the formatting button to your keyboard, you will need to assign a function to it. Click on the button and then select the formatting function that you want to use.
- Save the changes. Once you have added the formatting button and assigned a function to it, click the "Apply" button to save the changes.
I hope this helps! Let me know if you have any other questions.
1/2/2023 12:12:25 AM •
Logitech...
Answered
on Jan 02, 2023
Simple bluetooth support for logitech keyboard Y-raj56a?
Unfortunately, Logitech does not offer any Bluetooth support for the Logitech Y-RAJ56A keyboard. The keyboard is designed to be used with a wired connection, and it does not have any Bluetooth capabilities.
Yes, you can use a Bluetooth adapter to connect your Logitech Y-RAJ56A keyboard to a Bluetooth enabled device. However, you should bear in mind that the keyboard will not have any additional features or support when connected via Bluetooth.
So you will need to purchase a Bluetooth adapter. The Kinivo BTD-400 Bluetooth 4.0 USB Adapter is a good choice and is compatible with most versions of Windows and Mac.
P.S.
BTD400 Advisory
A recent update to Windows is preventing the BTD-400 from locating drivers automatically when plugged in for the first time. Please visit the article below to set up the BTD-400 Bluetooth Adapter for the first time.
BTD400 Driver Installation
12/31/2022 12:10:44 PM •
Logitech...
Answered
on Dec 31, 2022
I have Wansa smart TV and want to use Logitech wireless Arabic keyboard
you are going have to use the tv to search the internet for the logitech website try install the into the memory storage area in the tv or you mite have put the software or program installation software on a flash drive and plug it into usb plug on the tv. if that fail i have another idea try itunes see if they have generic drive that will work with the keyboard.
go to logitech website or tv website and post the same question to the forum members for help.
good luck rod
9/14/2021 4:30:09 PM •
Logitech...
Answered
on Sep 14, 2021
I have a Logitech m325 mice with unifying, i cannot connect with 2400 cordless keyboard.
this is in resonse to malware high jacker.
the OP mixed 2 wireless mice and keyboard/ mouse technologies, this will never work
1: bad batteries
2: use the drives form logitech or Microsoft only.
3: use the correct receiver, (they have 2 mixed and is dead to rights WRONG that)
4: RTM read the manual. dah"?
the mouse is 2011
the keyboard 2400 has mouse too and is 2006 made
the cure is kick the old keboard to the curb and use any wired keyboard
and then connect only the receiver from that new 2011 mouse.
it will plug and play. ok. (but is VISTA so gee, maybe not)
my guess is old 2400 mouse died
and bought the wrong mouse, that well never work with the 2400 parts ever.(mixed technology wirless)
Logitech m325
9/6/2021 3:21:43 PM •
Logitech...
Answered
on Sep 06, 2021
