20 Most Recent Samsung 61" Slim-Depth LED DLP HDTV Questions & Answers
The tv has sound has a picture but the picture
You need a red LED bulb. Same thing happened to me a few months back. Cost for the bulb and labor to put in about $500.
8/31/2013 5:14:56 PM • Samsung 61"... • Answered on Aug 31, 2013
2answers
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
6/6/2012 7:10:58 PM • Samsung 61"... • Answered on Jun 06, 2012
Sound, no picture Samsung DLP
Replace the Lamp. Mats has Lamps 1-800-628-1118
5/31/2011 11:04:38 PM • Samsung 61"... • Answered on May 31, 2011
The display does not show
Check for good connection from cable to TV , connection is good, check for a bad mother board TV board needs replaced
5/10/2011 7:13:39 PM • Samsung 61"... • Answered on May 10, 2011
0answers
TV went out, then came back on. Colors way off, no
Yes,but it could be the incomming broadcasting cable itself,it the cause?Take another tv,test it out with that incomming broadcasting cable,see,if that tv also lost the red color?Yes,than the LED tv have a bad tv Tuner signal board,replaced this incomming tv Tuner signal board,will solved this problems.The average years are 9-10 years,with average of used like 10 hours a day.That how long the LED screen panel will last,but the electronic PCB boards circuitries are a difference story.Those parts on the PCB boards circuittries could last for a couple years are less.
pC
11/30/2010 12:40:22 AM • Samsung 61"... • Answered on Nov 30, 2010
ABC DTV channels have distorted
Problem could be in the Main Board its the board that has your cable IF and AV jacks .
Encvompass Parts Distribution 1-800-638-3328
9/15/2010 11:36:30 AM • Samsung 61"... • Answered on Sep 15, 2010
Looking for technical help for Samsung 61" 1080p
Hope you got helpful info from our expert to solve your tv issue, if you still need further help, let me know to assist you further along with info what actions have been taken to fix the problem.
Thanks.
9/14/2010 8:42:31 AM • Samsung 61"... • Answered on Sep 14, 2010
Cant decide which type of tv is better
LED is a couple years old and so far not many complaints but they won't be around long. Plasma is much more expensive to repair but a great picture. LCD 120hz 1080p is probably the way to go if money is no object. Stay with a brand name such as Samsung, Panasonic, Sharp, stay away from Polaroid, Ilo, Dell, Westinghouse, Olevia, these are brands that have very poor customer support and parts availability. I am in the service industry and I see it everyday. Happy shopping...
5/22/2009 2:34:17 PM • Samsung 61"... • Answered on May 22, 2009
Samsung 61 inch issue
for clarification, may i know the model # of your TV? and do you have a problem on the sound
12/1/2008 6:31:49 AM • Samsung 61"... • Answered on Dec 01, 2008
Why is my Samsung plasma tv screen becoming dark suddenly meanwhile it's on and still functioning
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
4/16/2024 7:33:41 AM • Samsung... • Answered 2 hours ago
2answers
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM • Samsung... • Answered Yesterday
Samsung plasma tv repair PN51F5300BFXZA
All I can advise is to take it to an authorised Samsung repair shop. A list is available on the Samsung web site.
4/7/2024 8:20:50 AM • Samsung... • Answered on Apr 07, 2024
2answers
Samsung VHS VR8360C - if i use a three colour av cable on the VHS end and go to an HDMI connector at LG tv end will this work or do I need a converter?
The old yellow, red, white RCA cables are analogue signals, while HDMI cables only carry data. They are in no way compatible. You can buy active conversion boxes that will convert analog to digital, but simple cables cannot work
3/23/2024 10:44:12 PM • Samsung... • Answered on Mar 23, 2024
Remote code for Samsung remote to LG tv
It can't be done. The Samsung remote will be single frequency for that Samsung device only and the LG remote for that television (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 3:17:28 PM • Samsung... • Answered on Mar 19, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead. What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame. It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM • Samsung... • Answered on Feb 05, 2024
2answers
A resistor got burned on my samsung HT-E330K. I do not know its value because it got burned. Does anyone knows what it is?
Can you tell this power supply board zener doide value?
2/5/2024 2:11:29 PM • Samsung... • Answered on Feb 05, 2024
2answers
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described. Here are a few options you might consider:
  1. Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
  2. Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
  3. Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
  4. Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
  5. Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM • Samsung... • Answered on Feb 04, 2024
Samsung 61" Slim-Depth LED DLP HDTV Logo
17 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
decide type tv better
  • Televison & Video
