20 Most Recent Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Questions & Answers
In your Audio section of your PC find "Sound" and select Bluetooth rather than your speakers, and then do not forget to change it back when done.
Insignia... • Answered on Jan 12, 2017
1. There may be a switch on the headset. Please switch it on.
2. click Connect headset on the Bluetooth window
try 0000 (4 Zeros) if that doesn't work try one of these:
1111, 1234, 9999
Here's the link to the product manual: http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-324%20NS-BTHDP%20reduced%20-%20FINAL.pdf
Typical Bluetooth passcode is 0000.
Insignia support page points directly to Broadcom's, when it comes to software updates for Windows. Take look here.
Hope it works for you.
Cheers! Carlos
Insignia... • Answered on Jan 11, 2017
Windows 7 should automatically find the device and install the necessary software when you plug in the "Insignia" bluetooth transmitter. Once this is complete (can take a few minutes) you will need to connect your headset. It will connect and attemp to install drivers. It will not find the drivers on Windows Update, but instead it will tell you that you need to download a "Lenovo" driver and go to the broadcom website. Ignore Broadcom as they have removed this from detected devices and will just lock the system up. Instead download the Lenovo "Bluetooth with Enhanced Data Rate Software" driver that it suggests even though you may not have an IBM/Lenovo system.
The filename it downloaded for me was "7zbv14ww.exe", but if you do a google search there is a v15 available but I haven't tried it as the v14 is working perfectly fine for me.
Hope this helps.
Insignia... • Answered on Jan 10, 2017
if you have the latest update with A2DP.
hi u can get these ear cushions in all bluetooth  accessories shop...
bluetooth Passkey
By default all bluetooth devices come with a 0000 passskey must earpieces won't allow you to change it unless is a very high tech device.
try that remember 0000 is the code.
if it works for you don't forget to rate me
thx
You need a bluetooth adapter,
search for "bluetooth adapter for ipod" on Google or eBay, to see what's around.
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Insignia... • Answered on Jan 05, 2017
I bought this headset from Best Buy and it came with a usb dongle.  I also lost the disc.  Insignia's website is useless, and the Broadcomm update website is down at the time of this writing.  After hours upon hours of scouring, I found a working driver, which works perfectly.  This works on Windows XP, but I can't verify that it will work for Vista.    I hope this helps you.
http://drivers.anycom.com/bluetooth/usb-200-250/anycom-bluetooth-usb200-250-windows-v5-1-0-4200.exe
I will never buy Insignia products again because of their lack of driver support.
Best regards, RobotJay
Insignia... • Answered on Dec 26, 2016
try to use the code 0000
I had the same problem earlier. Try resetting the headset. Just plug it in to the charger, and press both volume buttons at the same time. It will turn off immediately. Wait a bit before turning it back on.
Insignia... • Answered on Dec 22, 2016
the code on the PC side should be 4 zero's, there is no code to set on the headphones side of things, just power the headphones on and on the PC set to serch for new devices.
Insignia... • Answered on Dec 20, 2016
Bluetooth can be very flakey. You might have a defective headset or dongle. It may have nothing to do with the drive.
But more likely is that something is messed up with the bluetooth drivers. If you installed the drivers on the disc that came with it, try uninstalling them. Reset the headset by pressing the volume up and down at the same time as described in the manual. This will clear all devices in memory. Then reinstall the drivers and try pairing again from scratch.
Good luck
Insignia... • Answered on Dec 17, 2016
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
120 questions posted
Top Insignia Radio Communications Experts
Marvin
Marvin
Lawrence Oravetz
ray gallant
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Radio Communications
Most Popular Question
need driver headset ns bthdp
  • Radio Communications
