20 Most Recent
Sirius Home Kit for SIRIUS Stiletto 2 Satellite Radio Receivers Questions & Answers
I have a Sirius Starmate ST2. It's stuck on 0% updating. Any suggestions? Antenna placement a d connection seems fine
Hard Reset:
Sometimes a hard reset can help. You can do this by pulling the fuse related to the Sirius system, letting it sit for a couple of minutes, and then putting it back in. Afterward, start the car, perform the Sync maintenance update, shut the car off, and then turn it back on.
If you're unsure about which fuse to pull, consult your vehicle's manual or seek professional assistance. But thee following may help. Behind the glovebox. There's 2 15amp fuses on the top-righthand side. It'll be the left one of those two.
Refresh the Signal:
Visit the SiriusXM signal refresh page and follow the instructions to refresh your SiriusXM signal. Note that you may need to select a specific channel during this process, but if the system is stuck, this might be challenging..
Check for Memory Leaks:
After disconnecting the battery, you mentioned that radio stations displayed their real frequency instead of "403" or incorrect frequencies. This suggests that there might be memory leaks in the Windows CE and Entertainment applications. Keep an eye on this behavior and consider reporting it to SiriusXM or seeking further technical support.
Remember that these steps are general troubleshooting suggestions,
HOW DO I FIND OUT WHAT SIRIUS XM ACCOUNT I AM BEING CHARGED FOR?
First look on your credit card statement. If that doesn’t help then get the ID from your Sirius device and compare to statement. Lastly call them with the ID. If you have multiple Devices, then any device that can receive channels is being billed somewhere....
Recover sirius stiletto2
that is a satellite radio that you have to pay for monthly or annually fixya has no information on that system
