20 Most Recent
Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black Questions & Answers
Griffin evolve speakers
The back plate is definitely snap off. As teodo mentioned, do not pull the entire rubber backing off. On the bottom and sides of the back plater there are two snaps, each directly on either side of the wider ridge along each edge.
The top is a different problem. The snaps are on the speaker side and clip onto the bottom of the upper edge of the back panel.
To remove the back plate: Start on the bottom of the speaker at the back edge. Pull away the rubber edge carefully to expose the joint between the back panel and the speaker box. Along the center of the of this joint on the panel is a wider ridge. Place a thin flat edged tool on one side of the ridge, pry, then push forcibly until the inner edge of the back plate is apart. Do this to each of the edges on the bottom and sides of the speaker. Don't peel away any rubber on the top side of the speaker. Press your flat edged tool into the joint and lift gently the back plate side of the joint before pushing it out. This will disengage the clips on that edge.
If you're looking to replace the batteries, they are 3.5V 5200maH.
Take Care
6/9/2013 4:55:58 PM •
Griffin...
Answered
on Jun 09, 2013
Griffin evolve remote not functioning
how did you take off the back to put in new batteries... try syncing your speakers by holding the 2 volume buttons on the base at the same time for about 2 secs.... the light will start to blink and you just click any button on your remote. If that doesnt work then its firmware
9/11/2012 8:47:45 PM •
Griffin...
Answered
on Sep 11, 2012
The speakers on my Griffin
Well, you did the right thing by verifying that the speakers are not the problem (they work in an identical system). Try connecting a different iPod, just to rule out that being a problem. Some of these docks need an adapter for some versions of the iPod... check to make sure you have the right one. Otherwise, if the base is defective, maybe you can get a replacement from Griffin. Contact their technical support staff. Good luck.
11/7/2010 5:10:19 AM •
Griffin...
Answered
on Nov 07, 2010
