Insignia 2.0... • Posted on Aug 25, 2017
Insignia 2.0... • Posted on Aug 03, 2017
Insignia 2.0... • Answered on May 16, 2016
Insignia 2.0... • Answered on Aug 18, 2014
Insignia 2.0... • Answered on Jul 02, 2014
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick ithope this helps
Insignia 2.0... • Answered on Jul 01, 2012
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
hope this helps you
Insignia 2.0... • Answered on Mar 22, 2012
Insignia 2.0... • Answered on Mar 20, 2012
Insignia 2.0... • Answered on Jul 18, 2011
Insignia 2.0... • Answered on Jul 05, 2011
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Insignia 2.0... • Answered on Jul 04, 2011
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is goodtry cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Insignia 2.0... • Answered on Jul 03, 2011
Insignia 2.0... • Answered on Jun 20, 2011
Insignia 2.0... • Posted on Jun 15, 2011
Insignia 2.0... • Answered on Jun 12, 2011
Insignia 2.0... • Answered on May 28, 2011
Insignia 2.0... • Answered on May 19, 2011
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer make sure you have an earth ******** before touching any parts inside your computer hope this helps
Insignia 2.0... • Answered on May 01, 2011
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Insignia 2.0... • Answered on Mar 25, 2011
62 questions posted
302 Questions
268 Questions
145 Questions
143 Questions
39 Questions
