20 Most Recent Euro-Pro Shark Rapido Electronic Iron - White/Gray Questions & Answers
vinegar the iron its calcified,it will clean out
Euro-Pro Shark... | Answered on Sep 10, 2013
La plancha tiene dos botones uno para sacar el agua y otro para el vapor y antes de esos dos tiene uno que cuando usted lo precione se mueve la temperatura
Euro-Pro Shark... | Answered on Mar 16, 2013
given the potential danger, and relative low expense, would you just consider trashing this and buying a new one? I don't intend to sound short or sarcastic....it's just with the burning smell I would prefer you either return it for refund, call the manufacturer or trash it for a different iron.
Looking at epinions.com there is a comperable iron for around $40-$50 with 24 reviews and 3.5 stars out of 5.
http://www.epinions.com/prices/pr-Black_Decker_D2030_Iron
Euro-Pro Shark... | Answered on Feb 23, 2012
the electrical cord of your iron maybe broken and makes contact now and again. thats the reason the light flashes when it makes contact..check it properly.good luck.
Euro-Pro Shark... | Answered on Sep 23, 2011
Ironing with a shark gi460 iron and it started smoking and it won't turn on now. Did it burn up? Is there away to repair it?
Euro-Pro Shark... | Answered on Aug 21, 2010
Limescale remover, like CLR or Limeaway, or whatever they sell at the hardware store.
Euro-Pro Shark... | Answered on May 26, 2010
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
Euro-Pro Irons | Answered on May 29, 2016
Could be a hidden recall. I'd check MFG website, or email their customer service.
Euro-Pro Irons | Answered on Apr 27, 2015
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
Euro-Pro Irons | Answered on Feb 02, 2015
Euro-Pro Shark Rapido Electronic Iron - White/Gray Logo
Popular Tags
12 questions posted
Top Euro-Pro Irons Experts
Sheldon Dedek
Andrew Taylor
Andrew Taylor
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
View Most Popular
Euro-Pro Irons
  • Euro-Pro Irons
Most Popular Question
steam button sticks in
  • Irons
