20 Most Recent Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Questions & Answers
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Whirlpool Duet... | Answered on Sep 22, 2011
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Whirlpool Duet... | Answered on Sep 11, 2011
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Whirlpool Duet... | Answered on Aug 18, 2011
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][[]][
Whirlpool Duet... | Answered on Aug 10, 2011
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Whirlpool Duet... | Answered on Aug 02, 2011
Press and hold the End of Cycle Signal button for 3 seconds or until the Control Lock indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle Signal button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
Whirlpool Duet... | Answered on Jul 18, 2011
If you have washed some NEW blue denims, some of the dye will get on everything. Blue denims are often a pain, and if you wear them before washing them they will get that same blue dye all over you.
It didn't hurt your washer, just run a couple loads through and add a little bleach to the whites. Note that if you put bleach in with OTHER colors, they will fade.
The trick is, never wash ANYTHING with blue denims, especially when they're new.
Whirlpool Duet... | Answered on Mar 05, 2011
Try holding down the CONTROL LOCK button down for about 3 seconds.
See if that works.
Comment back here if it doesn't and I will provide additional instructions if required.
Good luck.
Joe.
Whirlpool Duet... | Answered on Feb 27, 2011
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Whirlpool Duet... | Answered on Jan 14, 2011
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Whirlpool Duet... | Answered on Sep 30, 2010
It appears your timer/main controller/CCU has failed in this instance.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Whirlpool Duet... | Answered on May 03, 2010
take a boyyle of simple green solution, and get a clean rag, and this should take the stain off, after youwipe it down with this if it is coming off, wipe it down after with water, then dry it off with a clean rag, let me know if this gets it, it should thks larry
Whirlpool Duet... | Answered on Apr 25, 2010
Now did this happen all at once or did it slowly dry clothes slower and slower and then just quit? If it happened slowlt it is because you have some sort of ventalation blockage withing the dryer itself or in the wall of your home. When this happens it will the blow the thermal cut off and this will need to be replaced. If it happened over night then it could be the heating element or the thermal cut off & thermostat. All these can be checked with a volt meter using the setting for continuity.
Whirlpool Duet... | Answered on Mar 26, 2010
if your heating element is good then you need to check the thermal fuses in the cabinet if one of those is bad then it needs to be replaced.all thermal fuse should have continuity as well as the element if one of them does not have any continuity then replace it
Whirlpool Duet... | Answered on Mar 19, 2010
The flame should cycle on and off in response to the thermostat2.gif. If it is going out and not coming back on several minutes later then the exhaust vent may be clogged. Check the lint filter and exhaust vent all the way to the vent outlet to make sure they are not clogged.
Whirlpool Duet... | Answered on Dec 08, 2009
Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Gas Dryer - White-on-White Logo
38 questions posted
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
John Tripp
John Tripp
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
om dryer says control lock
  • Dryers
