20 Most Recent Bose Companion 5 Multimedia Speaker System (3-Piece) Questions & Answers
First, Is Bose companion 5 multimedia system a fuse type? If not how do i fix this?( I'll ask someone to do it though hehe)
Yes, the fuse is inside the unit where the power cord plugs in. Not accessible from outside the unit.
1/16/2016 2:10:30 PM • Bose Companion 5... • Answered on Jan 16, 2016
I plugged my 110v bose sound link 30 into a 220v outlet since . than its playing intermittently with out the bass
There is a good chance the device is damaged beyond repair and it may require replacement.
1/16/2016 2:09:18 PM • Bose Companion 5... • Answered on Jan 16, 2016
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
3/6/2015 11:52:49 PM • Bose Companion 5... • Answered on Mar 06, 2015
I missing control
12/10/2014 4:17:39 PM • Bose Companion 5... • Answered on Dec 10, 2014
Bose repair
Does not seem very complex. I think it is because of the broken fuse. Simply Open the back part of Bose companion 5. The Circuit board attached to the back part is basically for the Audio output socket, Control pod Connector and Power supply connector. on the Left hand side of the board you will find a fuse soldered with the board. most probably that fuse is broken. replace the fuse if broken or just connect both end of the fuse with thin wire (temporary) to check. Hope it helps. I am outta home or else i could have added an image for you. maybe tomorrow. Thanks
6/24/2014 6:30:26 PM • Bose Companion 5... • Answered on Jun 24, 2014
2answers
Hello, i have a dell
Is there any system to which you can connect your BOSE *and* have it work?
If not, then check that the BOSE is getting electrical power into it.
5/14/2014 2:12:38 PM • Bose Companion 5... • Answered on May 14, 2014
Buzzing speakers
Might be interference from a wireless source like a cell phone.
3/15/2014 6:03:40 PM • Bose Companion 5... • Answered on Mar 15, 2014
Need new control pod for companion 5
Can you explain the problems you are having for dropping it many times? Is it just physically damaged from outside / The cuircit inside is broken / Completely dead? Would be easier for me to solve the problem. Few days ago I bought a new Control pad from ebay which was $85. See, if the circuit is broken inside or the cable is damaged surely we can come with a solution.. I have a working control pad Cuircit and other spare parts.. so if u can find out the part needs to be replaced then i am sure u can cut down this expense. Thanks.
3/7/2014 12:57:11 PM • Bose Companion 5... • Answered on Mar 07, 2014
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
131 questions posted
Top Bose Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
first bose companion 5 multimedia
  • Audio Players & Recorders
