20 Most Recent Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Questions & Answers
Sound like you need to replace the heating element.
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Whirlpool Cabrio... | Answered on Apr 28, 2016
press the cycle sensor button for 3 seconds.. that resets it
Whirlpool Cabrio... | Answered on Jan 09, 2016
If you can hear the dryer motor running it is most likely a broken belt or idler.
Whirlpool Cabrio... | Answered on Aug 06, 2014
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Whirlpool Cabrio... | Answered on Jan 01, 2014
Disconnect power for 30 sec. reapply power and observe for 1 minute
if code still appears replace control board (erc clock)
Whirlpool Cabrio... | Answered on Feb 04, 2013
Not a major appliance expert--but if the situation is as described with hot air out vent but not in the drum where the clothing is it seems to me you have a blockage between the drum and lint filter to where it reaches the vent tube---they do make long flexible brushes for this-----a suggestion: if you have a compressor try forcing air down from the lint filter with the vent tube removed to see if the blockage is there and will clear or not.
A blockage can be a fire hazard so if you do not find it have a tech out.
Whirlpool Cabrio... | Answered on Dec 06, 2012
Can you spin the drum freely by hand?
Whirlpool Cabrio... | Answered on Nov 25, 2012
An EXTREMELY helpful technical guide is folded inside the console housing.
WARNING: It is for appliance techs, DO NOT do the voltage/resistance checks if you are not well-versed in troubleshooting appliances! BUT, it does include putting the dryer in diagnostics mode and checking the sensors.
Post back any error codes you may get.
Whirlpool Cabrio... | Answered on Oct 23, 2012
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Whirlpool Cabrio... | Answered on Sep 03, 2011
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
Whirlpool Cabrio... | Answered on Jul 18, 2011
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
44 questions posted
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
when start drying
  • Dryers
